Server Version#: 4.146.0 (running on debian 12)
Player Version#: NA
Server Version#: 1.41.7.9795-b8182f5e6
OS: Debian 12
I’m seeing abnormal growth in Plex’s com.plexapp.plugins.library.db file. It suddenly jumped from ~4 GB to over 11 GB in less than 10 hours, even though no new media was added and Plex had minimal usage.
This Plex VM has been stable for years and usually grows slowly over time, but this sudden spike is not normal.
After investigating, I identified that the issue comes from the statistics_bandwidth table inside the database.
Example:
10:00 AM — statistics_bandwidth: ~946,000 rows
06:00 PM — statistics_bandwidth: ~166,385,000 rows
When I manually cleared this table, the database size went back down to its usual ~4 GB.
My questions:
- What causes
statistics_bandwidthto fill up so aggressively? - Is this a bug, or is there something in my setup triggering excessive bandwidth tracking?
- Is there a way to limit or disable this behavior?
- Is there a proper/official way to manage or rotate the data in
statistics_bandwidth?
Any insights would be much appreciated. Thanks!
Xavier
