@sa2000 I re-ran the command /usr/lib/plexmediaserver/Plex\ Media\ Scanner --verbose --scan --refresh --progress --no-thumbs --section 2 --directory /mnt/nt/J-M/Jamie\'s\ Great\ Italian\ Escape/ > /tmp/scan.log 2>&1
and have attached it here: https://nextcloud.progressivethink.in/index.php/s/PXSDAeegmjNfVLS the password is the same as the last archive.
The output of the command can be found in scan.log
For what it is worth, I did run the previous command with --verbose and --progress in the last batch of logs. I did not see much of a difference between the output I copied and pasted before and what was logged this go around, but meh. \o/
@eldon.mcguinness said: @sa2000 I re-ran the command /usr/lib/plexmediaserver/Plex\ Media\ Scanner --verbose --scan --refresh --progress --no-thumbs --section 2 --directory /mnt/nt/J-M/Jamie\'s\ Great\ Italian\ Escape/ > /tmp/scan.log 2>&1
I need to know the time of start and end of the scan. The scan.log does not tell me what time it started and what time it finished. And the named media items in the the scan.log, what are the actual paths for them?
The scan.log shows one path being scanned GUI: Scanning Jamie's Great Italian Escape
and then within that, I presume, there are 40+ items being scanned / matched.
Any of these outside the Jamie's Great Italian Escape directory?
PS: There have been significant changes to how the scanner runs in recent versions and the environment for the scanner jobs need to bet set to allow access to codecs libraries. So even if we get to the bottom of what the issue is with regards to the partial directory scanning, there will be other issues and I am not sure at this stage if this command line interface will continue to be supported
I donât have the times the scan ran, though I can tell you that is a fresh restart of Plex with empty logs so the stamps IN the log should be spot on. As for the scan ending, I waiting for the log file to quit being appended to and then stopped the service, so the approximately seven (7) minute window in the logs should contain the information needed. I canât imagine much outside noise got into the logs.
As for the file locations:
/mnt/nt/J-M/Jamies Great Italian Escape (Folder I'm scanning)
/mnt/nt/A-C/Absolute Genius Monster Builds
/mnt/nt/T-V/The After Party 2017
/mnt/nt/A-C/Beachin Rvs
/mnt/nt/A-C/Bikinis and Ski Slopes
/mnt/nt/A-C/Biq Digits
/mnt/nt/A-C/Bitchin Rides: High Octane
/mnt/nt/A-C/Britain at War Imperial War Museum At
/mnt/nt/A-C/Celebrities: In Therapy
/mnt/nt/D-F/Everyday Innovators
/mnt/nt/D-F/Flame Halfworlds
/mnt/nt/D-F/Flog It Trade Secrets
/mnt/nt/D-F/Fonejacker Christmas Special
/mnt/nt/G-I/Gareth Wyn Jones Milk Man
/mnt/nt/G-I/Hairspray Live
/mnt/nt/G-I/Hayley Bikinis Bars and Benidorm
/mnt/nt/G-I/History Channel Leonardo Da Vincis Book of Secrets
/mnt/nt/G-I/Holland Casino Met De Kaarten Op Tafel
/mnt/nt/G-I/Hotel Impossible 5 Star Secrets
/mnt/nt/G-I/How to Live Mortgage Free With Sarah Beeny
/mnt/nt/J-M/Kirsties Handmade Treasures
/mnt/nt/A-C/A League of Their Own Uk Us Road Trip
/mnt/nt/J-M/Lego Nexo Knights: The Book of Monsters
/mnt/nt/J-M/Matthew Evans for the Love of Meat
/mnt/nt/J-M/Mind Over Money With Nigel Latta
/mnt/nt/J-M/Mission Critical
/mnt/nt/N-P/Pop Quiz 2016
/mnt/nt/Q-S/Reggie Yates Hidden Australia
/mnt/nt/Q-S/Roaring With Pride
/mnt/nt/Q-S/Ross Kemp Libyas Migrant Hell
/mnt/nt/Q-S/Saved at the Heart of the Health Service
/mnt/nt/Q-S/Sicily Wonder of the Mediterranean
/mnt/nt/Q-S/Sicily Wonder of the Mediterranean 2017
Any of these outside the Jamieâs Great Italian Escape directory?
YES, that really is the key to the issue. ALL of them are in their correspondingly named folders in the /mnt/nt/ folder, clearly outside of the folder being scanned.
PS: There have been significant changes to how the scanner runs in recent versions and the environment for the scanner jobs need to bet set to allow access to codecs libraries. So even if we get to the bottom of what the issue is with regards to the partial directory scanning, there will be other issues and I am not sure at this stage if this will continue to be available
I canât imagine this will make many people happy as the alternative is a complete scan of the entire root node for those of us who use network locations for our media. Without this we are going to be thrashing our hdds and putting undue load on the servers and network due to the fact that most network storage do not have inotify et. al. Please tell me Iâm misunderstanding what you mean by âthis may not be available in the future.â What capacity/tool will be made available to trigger a partial scan or a scan of a particular directory like we, we being myself and other plex users, are trying to achieve if this is no longer available?
@âMovieFan.Plexâ Well, Iâm going to assume we can agree that at a minimum the --scan, --section, and --directory options would be kept as without those we would not be scanning the desired directory and we would not be specifying to what section the media should be added.
âscan
I started with: /usr/lib/plexmediaserver/Plex\ Media\ Scanner --scan --section 2 --directory SOMEDIRECTORY
This stays IN the desired directory and DOES NOT trigger the extra files, which are outside of the folder specified as the directory to scan. However, this also does not result in any tagging or art working being fetched.
Seeing that issue I proceeded to add the --refresh option, which results in the files in the specified directory being scanned AND tagged, but it also results in the UNMATCHED media OUTSIDE of the specified directory to attempt to be matched.
âno-thumbs
The --no-thumbs option was added later, in both cases, in an attempt to try and stop thumbs from being generated as I donât require them. In either case: /usr/lib/plexmediaserver/Plex\ Media\ Scanner --scan --no-thumbs --section 2 --directory SOMEDIRECTORY OR /usr/lib/plexmediaserver/Plex\ Media\ Scanner --scan --refresh --no-thumbs --section 2 --directory SOMEDIRECTORY
âprogress and --verbose
These tags were added to try and get a better picture as to what is going on and to provide error/logging information here.
For what it is worth, I have tried both the letter and word forms of these options and they result in the same thing.
ârefresh /usr/lib/plexmediaserver/Plex\ Media\ Scanner --scan --refresh --section 2 --directory /mnt/nt/J-M/Jamie\'s\ Great\ Italian\ Escape/
That doesnât sound right. It should stay in that folder and subfolders, unless itâs the subfolders you mean. There isnât a way to restrict scanning to ONLY a folder (itâs the folder and all subfolders). If the above is scanning other folders, thatâs wrong.
I gave the following a try with the same results: /usr/lib/plexmediaserver/Plex\ Media\ Scanner --scan --refresh --section 2 --directory /mnt/nt/J-M/Jamie\'s\ Great\ Italian\ Escape/
GUI: Requesting metadata for ââthe Railwayâ: Inside Kingâs Crossâ
As you can see it is scanning the desired folder and then proceeding to try to match files that were not previously matched, ALL of which are NOT in the /mnt/nt/J-M/Jamie\'s\ Great\ Italian\ Escape/ folder. You can see where many of these files are by looking at this previous post.
@MovieFan.Plex said:
Try removing the last â/â. I donât use Linux, but on my Windows system, adding the last "" makes it not work.
Just tried it and I get the same result.
As I said before, it just seems like the --refresh option forces Plex to not only refresh the file in the directory, but also to try to match/tag anything that it has not been able to match/tag before. All of the shows that are showing as âmatchingâ as shows that have not been âmatchedâ in Plex. I hope what Iâm trying to get across here is making sense. The expected behaviour would be for the refresh to be limited to the files/folders specified by the --directory option. If you are not seeing this on your side, try to create a show that does not have a match via the Plex/TVDB/TMDB scanners and see if that helps to reproduce it. I have been able to reproduce this on every machine/vps Iâve tried it on and the only time I do not see this is when I have ALL of the shows in my library properly matched.
Sorry, nothing to add.
Just need to make a post to get rid of the stupid forum message about unanswered questions pop up even when there are no posts to accept or reject. afaik it happens when you have clicked no, then the post gets edited and the forum thinks something needs an answer but does not display the yes no button. Its a problem that has been around for a long timeâŠ
Could the environment settings be the root of my problem here. All I have set currently, is:
Could be - not sure. Need to look into it.
But you may be able to help here - you appear to have got a real Plex Media Scanner log file for your command line job whereas @âeldon.mcguinnessâ did not. This too could be environment variable related !
The scanner process when invoked internally by Plex Media Server does have additional environment variables introduced recently. The ones that specify paths are
EAE_ROOT
FFMPEG_EXTERNAL_LIBS
and there is also environment variable for the server token X_PLEX_TOKEN
As the syntax for the path varies from platform to platform and also may be different for different versions of Plex Media Server, I am not going to try and tell you what these extra environment variables should be set to but best to get a scan fired by Plex Media Server and then look at the Plex Media Server.log to see what the paths are set to for the scanner job logged line
This is an example of what the log file entry would look like
May 11, 2017 10:54:11.704 [19568] DEBUG - Job running: EAE_ROOT='\\?\C:\Users\plex\AppData\Local\Plex Media Server\Transcoder\EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='\\\\?\\C\:\\Users\\plex\\AppData\\Local\\Plex\ Media\ Server\\Codecs\\e96c1d3-1208-windows-i386\\' X_PLEX_TOKEN='xxxxxxxxxxxx' C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe --scan --refresh --section 28 --directory C:\Users\Public\Plex-Tests\Home-Video-Tests
The environment variables would be set to the text within the ' characters showing in the log line
@sa2000 I found another log file in another location that might be what youâre looking for, I have included it in the archive below with all the other data collected again as well:
Plex Media Scanner.Log is from /var/lib/plexmediaserver/Library/Logs
Plex Media Server.Log is from /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs
As for environmental variables, the only one that I am setting when I switch to the plex user vi su is LD_LIBRARY_PATH=/usr/lib/plexmediaserver
I found a section of the new log file very interesting, you can see on line 33 it finished scanning the specified folder, then on line 34 it starts a âRefreshing section 2 of type: 2â. Now, while I am not a developer here, it sounds to me like it is not telling the service to stay inside the directory and instead performs a refresh of the entire section.
@eldon.mcguinness said: @sa2000 I found another log file in another location that might be what youâre looking for, I have included it in the archive below with all the other data collected again as well:
That is exactly what is happening after scanning the directory path. It is doing a refresh without restricting it to the specified directory
Now that we have the log confirming this, I am raising it with the development team
@âMovieFan.Plexâ said:
Do you have âAutoupdate libraryâ enabled? Iâm wondering if the command line is then triggering that.
No it is not.
We have FSEventLibraryUpdatesEnabled="0"
@âeldon.mcguinnessâ Could you do me a directory test when the directory is below the root of that location.
The library has multiple locations and you are scanning a whole location using the --directory parameter
Could you try adding a TV Show below the root of that location and having the directory of that TV Show as the parameter and let me know the outcome
Tell me if this is what you mean, I used to have my TV library arranged in this manner: /mnt/nt/showname/showname.s01e01.ts
but recently I changed it to /mnt/nt/Q-S/showname/showname.s01e01.ts
During both times Iâve had /mnt/nt as the directory that is scanned by Plex. In the former case I would scan /mnt/nt/showname instead of the current location format which is /mnt/nt/Q-S/showname.
It sounds to me like you want to to try the way I used to have it organized, is that correct? If so then I can tell you now that I had the same issue at that time as well. If that is not what you mean then could you give me an example?
but recently I changed it to /mnt/nt/showname/Q-S/showname.s01e01.ts
At the moment it is a theory
Actually you are already specifying a TV Show name as a parameter
At the moment you have this as a location /mnt/nt/J-M/ and you are specifying the path /mnt/nt/J-M/Jamie's Great Italian Escape/
Lets change the test to adding a Season folder /mnt/nt/J-M/Jamie's Great Italian Escape/Season 01
and move the episodes below that
and the command line to try
Could the Q-S be the problem. That is where you would normally see a SEASON folder. Is this even supported?
