I moved the Jamie’s Great Itallian Escape shows to the root of /mnt/nt and give it an appropriate structure. It is currently running, but a snippet from the top shows the same thing.
But, after looking at the logs, this will not work as /mnt/nt is not a valid section, I would have to add a new directory to the list and the like. I guess, from Plex’s point of view, the scan is actually looking at the root of the section which is /mnt/nt/J-M in this case.
I ran /usr/lib/plexmediaserver/Plex\ Media\ Scanner -v -p -r -s -c 2 -d /mnt/nt/J-M/Jamie\'s\ Great\ Italian\ Escape/Season\ 01/
Here is what a top snippet off the top of the scanner log, it is currently still running and I will upload a full copy for ya. It looks to be doing the same thing.
Here is, what should be, the full log
nextcloud.progressivethink.in/index.php/s/XYMsKreo30MRWxW
May 11, 2017 17:29:44.755 [0x7f3ee6638700] INFO - /usr/lib/plexmediaserver/Plex Media Scanner -v -p -r -s -c 2 -d /mnt/nt/J-M/Jamie's Great Italian Escape/Season 01/
May 11, 2017 17:29:44.755 [0x7f3ef24f4800] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.13.0, threadsafe=1
May 11, 2017 17:29:44.853 [0x7f3ef24f4800] DEBUG - It took 20.000000 ms to retrieve 2269 items.
May 11, 2017 17:29:49.798 [0x7f3ef24f4800] DEBUG - It took 0.000000 ms to retrieve 2269 items.
May 11, 2017 17:29:54.871 [0x7f3ef24f4800] DEBUG - It took 10.000000 ms to retrieve 2269 items.
May 11, 2017 17:29:59.887 [0x7f3ef24f4800] DEBUG - It took 10.000000 ms to retrieve 2269 items.
May 11, 2017 17:30:04.927 [0x7f3ef24f4800] DEBUG - It took 20.000000 ms to retrieve 2269 items.
May 11, 2017 17:30:09.940 [0x7f3ef24f4800] DEBUG - It took 10.000000 ms to retrieve 2269 items.
May 11, 2017 17:30:15.167 [0x7f3ef24f4800] DEBUG - It took 10.000000 ms to retrieve 2269 items.
May 11, 2017 17:30:20.147 [0x7f3ef24f4800] DEBUG - It took 20.000000 ms to retrieve 2269 items.
May 11, 2017 17:30:25.069 [0x7f3ef24f4800] DEBUG - It took 10.000000 ms to retrieve 2269 items.
May 11, 2017 17:30:30.242 [0x7f3ef24f4800] DEBUG - It took 10.000000 ms to retrieve 2269 items.
May 11, 2017 17:30:35.473 [0x7f3ef24f4800] DEBUG - It took 20.000000 ms to retrieve 2269 items.
May 11, 2017 17:30:40.444 [0x7f3ef24f4800] DEBUG - It took 10.000000 ms to retrieve 2269 items.
May 11, 2017 17:30:45.405 [0x7f3ef24f4800] DEBUG - It took 10.000000 ms to retrieve 2269 items.
May 11, 2017 17:30:50.306 [0x7f3ef24f4800] DEBUG - Scanning TV Shows using en(Plex Series Scanner) with 0 current media items in the database...
May 11, 2017 17:30:50.306 [0x7f3ee4fff700] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/cullTimeline?librarySectionID=2&sinceTime=1494537050
May 11, 2017 17:30:50.308 [0x7f3ee4fff700] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/notify/cullTimeline?librarySectionID=2&sinceTime=1494537050
May 11, 2017 17:30:50.367 [0x7f3ef24f4800] DEBUG - Performing a scan with 'Plex Series Scanner' (language: en virtual: 0).
May 11, 2017 17:30:50.367 [0x7f3ef24f4800] DEBUG - * Scanning /mnt/nt/J-M/Jamie's Great Italian Escape/Season 01
May 11, 2017 17:30:50.432 [0x7f3ef24f4800] DEBUG - * Scanning directory /mnt/nt/J-M/Jamie's Great Italian Escape/Season 01 (parent: yes)
May 11, 2017 17:30:50.435 [0x7f3ef24f4800] VERBOSE - * Noting that 'Jamie's Great Italian Escape/Season 01' was updated at 2017-05-11 21:28:49
May 11, 2017 17:30:50.435 [0x7f3ef24f4800] VERBOSE - * Taking directory 'Jamie's Great Italian Escape/Season 01' (25687) out of the map (0 left)
May 11, 2017 17:30:50.438 [0x7f3ef24f4800] DEBUG - Adding file for scanner: /mnt/nt/J-M/Jamie's Great Italian Escape/Season 01/Jamie's Great Italian Escape.s01e06.mkv
May 11, 2017 17:30:50.440 [0x7f3ef24f4800] DEBUG - Adding file for scanner: /mnt/nt/J-M/Jamie's Great Italian Escape/Season 01/Jamie's Great Italian Escape.s01e05.mkv
May 11, 2017 17:30:50.445 [0x7f3ef24f4800] DEBUG - Directory had 2 files, database had 0 files, can't skip.
May 11, 2017 17:30:50.454 [0x7f3ef24f4800] DEBUG - * Scanning Jamie's Great Italian Escape Season 1 Episode 5
May 11, 2017 17:30:50.454 [0x7f3ef24f4800] DEBUG - Looking for path match for [/mnt/nt/J-M/Jamie's Great Italian Escape/Season 01/Jamie's Great Italian Escape.s01e05.mkv]
May 11, 2017 17:30:55.038 [0x7f3ef24f4800] DEBUG - Checking by hash to see if we can find a match with 2aec3186b5517429058a7ae2047891246386939a (display offset: 0, not part -1)
May 11, 2017 17:30:55.038 [0x7f3ef24f4800] DEBUG - We found a hash match for [/mnt/nt/J-M/Jamie's Great Italian Escape/Season 01/Jamie's Great Italian Escape.s01e05.mkv] which was [/mnt/nt/J-M/Jamie's Great Italian Escape/Jamie's Great Italian Escape.s01e05.mkv].
May 11, 2017 17:30:55.051 [0x7f3ef24f4800] INFO - Part rename detected [/mnt/nt/J-M/Jamie's Great Italian Escape/Jamie's Great Italian Escape.s01e05.mkv] was renamed [/mnt/nt/J-M/Jamie's Great Italian Escape/Season 01/Jamie's Great Italian Escape.s01e05.mkv]
May 11, 2017 17:30:55.083 [0x7f3ef24f4800] DEBUG - Updating media item 415707, size=424717925, metadata_item_id=266480
May 11, 2017 17:30:55.133 [0x7f3ef24f4800] DEBUG - Updating part with ID=431546 [/mnt/nt/J-M/Jamie's Great Italian Escape/Jamie's Great Italian Escape.s01e05.mkv]
May 11, 2017 17:30:55.137 [0x7f3ef24f4800] DEBUG - Turbo analysis on modified item 415707 [/mnt/nt/J-M/Jamie's Great Italian Escape/Jamie's Great Italian Escape.s01e05.mkv]
May 11, 2017 17:30:55.142 [0x7f3ef24f4800] DEBUG - Updating media item 415707, size=849435850, metadata_item_id=266480
May 11, 2017 17:30:55.150 [0x7f3ef24f4800] DEBUG - Updating part with ID=431546 [/mnt/nt/J-M/Jamie's Great Italian Escape/Jamie's Great Italian Escape.s01e05.mkv]
May 11, 2017 17:30:55.159 [0x7f3ef24f4800] VERBOSE - Added new media part with ID=440541 [/mnt/nt/J-M/Jamie's Great Italian Escape/Season 01/Jamie's Great Italian Escape.s01e05.mkv]
May 11, 2017 17:30:55.210 [0x7f3ef24f4800] DEBUG - * Scanning Jamie's Great Italian Escape Season 1 Episode 6
May 11, 2017 17:30:55.210 [0x7f3ef24f4800] DEBUG - Looking for path match for [/mnt/nt/J-M/Jamie's Great Italian Escape/Season 01/Jamie's Great Italian Escape.s01e06.mkv]
May 11, 2017 17:31:01.241 [0x7f3ef24f4800] DEBUG - Checking by hash to see if we can find a match with 5cde9aca6e8402c8dd4e40c91c2ee748458b07b1 (display offset: 0, not part -1)
May 11, 2017 17:31:01.241 [0x7f3ef24f4800] DEBUG - We found a hash match for [/mnt/nt/J-M/Jamie's Great Italian Escape/Season 01/Jamie's Great Italian Escape.s01e06.mkv] which was [/mnt/nt/J-M/Jamie's Great Italian Escape/Jamie's Great Italian Escape.s01e06.mkv].
May 11, 2017 17:31:01.245 [0x7f3ef24f4800] INFO - Part rename detected [/mnt/nt/J-M/Jamie's Great Italian Escape/Jamie's Great Italian Escape.s01e06.mkv] was renamed [/mnt/nt/J-M/Jamie's Great Italian Escape/Season 01/Jamie's Great Italian Escape.s01e06.mkv]
May 11, 2017 17:31:01.269 [0x7f3ef24f4800] DEBUG - Updating media item 415708, size=402451229, metadata_item_id=266481
May 11, 2017 17:31:01.278 [0x7f3ef24f4800] DEBUG - Updating part with ID=431547 [/mnt/nt/J-M/Jamie's Great Italian Escape/Jamie's Great Italian Escape.s01e06.mkv]
May 11, 2017 17:31:01.282 [0x7f3ef24f4800] DEBUG - Turbo analysis on modified item 415708 [/mnt/nt/J-M/Jamie's Great Italian Escape/Jamie's Great Italian Escape.s01e06.mkv]
May 11, 2017 17:31:01.294 [0x7f3ef24f4800] DEBUG - Updating media item 415708, size=804902458, metadata_item_id=266481
May 11, 2017 17:31:01.303 [0x7f3ef24f4800] DEBUG - Updating part with ID=431547 [/mnt/nt/J-M/Jamie's Great Italian Escape/Jamie's Great Italian Escape.s01e06.mkv]
May 11, 2017 17:31:01.326 [0x7f3ef24f4800] VERBOSE - Added new media part with ID=440542 [/mnt/nt/J-M/Jamie's Great Italian Escape/Season 01/Jamie's Great Italian Escape.s01e06.mkv]
May 11, 2017 17:31:01.343 [0x7f3ef24f4800] DEBUG - Removing 0 media items that were left.
May 11, 2017 17:31:01.343 [0x7f3ef24f4800] DEBUG - Removing 0 directories that were left.
May 11, 2017 17:31:01.343 [0x7f3ef24f4800] DEBUG - Updating directory 'Jamie's Great Italian Escape/Season 01' (ID 25687) to time 2017-05-11 21:28:49.
May 11, 2017 17:31:01.417 [0x7f3ef24f4800] DEBUG - Refreshing section 2 of type: 2
May 11, 2017 17:31:01.443 [0x7f3ef24f4800] DEBUG - The show 'Absolute Genius Monster Builds' needs refreshing, no match yet.
May 11, 2017 17:31:01.454 [0x7f3ef24f4800] DEBUG - The show 'The After Party 2017' needs refreshing, no match yet.
May 11, 2017 17:31:01.551 [0x7f3ef24f4800] DEBUG - The show 'Beachin' Rv's' needs refreshing, no match yet.
May 11, 2017 17:31:01.583 [0x7f3ef24f4800] DEBUG - The show 'Bikinis and Ski Slopes' needs refreshing, no match yet.
May 11, 2017 17:31:01.589 [0x7f3ef24f4800] DEBUG - The show 'Biq Digits' needs refreshing, no match yet.
May 11, 2017 17:31:01.591 [0x7f3ef24f4800] DEBUG - The show 'Bitchin' Rides: High Octane' needs refreshing, no match yet.
May 11, 2017 17:31:01.634 [0x7f3ef24f4800] DEBUG - The show 'Britain at War Imperial War Museum At' needs refreshing, no match yet.
May 11, 2017 17:31:01.672 [0x7f3ef24f4800] DEBUG - The show 'Celebrities: In Therapy' needs refreshing, no match yet.
May 11, 2017 17:31:01.867 [0x7f3ef24f4800] DEBUG - The show 'Everyday Innovators' needs refreshing, no match yet.
May 11, 2017 17:31:01.906 [0x7f3ef24f4800] DEBUG - The show 'Flame Halfworlds' needs refreshing, no match yet.
May 11, 2017 17:31:01.914 [0x7f3ef24f4800] DEBUG - The show 'Flog It Trade Secrets' needs refreshing, no match yet.
May 11, 2017 17:31:01.922 [0x7f3ef24f4800] DEBUG - The show 'Fonejacker Christmas Special' needs refreshing, no match yet.
May 11, 2017 17:31:01.954 [0x7f3ef24f4800] DEBUG - The show 'Gareth Wyn Jones Milk Man' needs refreshing, no match yet.
May 11, 2017 17:31:02.021 [0x7f3ef24f4800] DEBUG - The show 'Gutsful!' needs refreshing, no match yet.
