It would be cool to have an “easy button” to process recordings for the last year.
I can confirm it’s working again. Thank you, team! It chops of the end of my shows, but that’s a different topic
If you’re on windows, drag and drop the files into MCEBuddy and point it to the same compskip.ini file - it will use them for comskip and process them as if it was done by plex itself.
I assume this requires a download of MCEBuddy? Not trying to be a butt… but that’s not part of the standard Plex install, right?
Yes it’s a separate install - http://mcebuddy2x.com/
You’ll need to choose what you want to transcode the videos into (or not, if you prefer) - it’s pretty intuitive.
I’m also using MCEBuddy thanks to WCTschumy’s recommendation. Couldn’t wait over 6 months for a fix. Maybe for the best though since I can do more with MCEBuddy and might not have bought it otherwise.
Awesome!! This explains it working in some situations and not others. I hate character limits!
This is fantastic news! Do we know how long it’ll be in beta before being pushed to the masses?
1.20.1 is now public
2 posts were split to a new topic: Unable to set Detect and delete commercials for a specific recording
Hi, it is still broken for me. SD works but HD emissions fail consistently.
I use VBox and I am in Spain. It is the HD channels that make the commertial skip fail.
I have plex for Synology 1.20.1.3252 intel 64 bit
Please raise a new forum topic for this with server logs covering the time when the Plex commercial skipper fails - make sure you run with debug logging enabled on the server and restart the server to get fresh logs before reproducing the problem
you can add a post here to link to your new forum topic
Your issue is not the same to what was fixed for the problem reported in this forum thread
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
