Server Version#: 1.20.1.3252
Player Version#: 1.19.0.1399-31d8c803
Tuner Make/Model: HDHomeRun Extend
Guide/Lineup name: Broadcast TV
Using XMLTV?: Unknown
Channel number/Name: All
Not sure where to submit a bug report to, but here goes:
There appears to be a bug in this server version. When modifying the advanced options of a recording, the “Detect Commercials” setting always seems to stick on whatever the DVR is set to.
For example, I have the DVR set to “Detect commercials and delete” but there is a program where the commercial detection isn’t very good. I went to the recording, and changed the setting to “Disabled”. However, when I go back to verify the change was made, it goes back to “Detect commercials and delete.” I changed the parent DVR setting, and it looks like ie propagated to all recordings now even then ones I am fairly confident were set to “Use DVR Setting.”
