Server Version#: 1.20.5.3600
OS Version: Windows 7 Ultimate SP1
Player Version#: Plex Web 4.46.2 (not applicable)
Tuner Make/Model: HDHomeRun PRIME
Guide/Lineup name: Verizon Fios
Using XMLTV?: No
Channel number/Name: All
I have all recordings set to “Detect commercials and mark for skip”
I can see in the logs that Plex Commercial Skipper.exe is being run against the recording
(line 8546 of Plex Media Server.log).
I can see that commercials have been found and the EDL was built (line 10485).
But when I view the media’s XML, there are no commercial segments in it. (File removed)
I do not see a .EDL file next to the recording on my drive (I’m assuming it was cleaned up based on the log message on line 10485).
So…I run the file through Plex Commercial Skipper.exe via the command prompt via: C:\Users\SageAdmin>“C:\Program Files (x86)\Plex\Plex Media Server\Plex Commercia
l Skipper.exe” “–ini=C:\Users\SageAdmin\AppData\Local\Plex Media Server\DVR\com
skip.ini” “–output=D:\The Rachael Ray Show (2006)\Season 15” -t --quiet “D:\The
Rachael Ray Show (2006)\Season 15\The Rachael Ray Show (2006) - S15E47 - The Ca
ke Boss Buddy Valastro is Baking in His First TV Demo Since His Hand Injury.ts”
It, in turn, generates the .edl, .log, .logo.txt, and .txt file as expected by Comskip and shows two commercial segments in the .edl file.
So…how come the commercial segments are not making their way into the show’s XML in PMC?
Logs attached
(File removed)
