No options to skip intros or commercials
I made a recording on the Plex DVR and the xml exists with lots of commercials in it, but Plex on the fire stick is not giving me the option to skip ads.
What logs do you need to help diagnose this? Verbose logging is already on so I should be able to get you some logs immediately.
There are settings for this in the Tuner/DVR section.
You have to turn those options on, I think there is one for each tuner.
Settings for what? I already have it scanning. The file does scan and I’m left with an xml file full of commercial segments.
The XML is temporary, I believe it should immediately get written over to the DB entry for the video right away. Once a video records, there is no need to retain the XML file, and I have never seen any stored with any of my recordings.
Well, with my installation, it never goes away unless I delete the episode.
That could mean that it isn’t finishing.
Hopefully someone from Plex can help with this soon.
It’s a good possibility I need to wipe the database of all things DVR. Anyone know how to do it and can help me out, it would be appreciated.
Also, in the status window (drop down) I never see anything close to “Scanning for commercials”.
Ok, let’s check to see if the setting is even enabled for you then.
  • Go to settings, then on the left-hand menu scroll to the bottom and click on Live TV & DVR. This should list your DVR, and the discovered channels.
  • In the upper right, click on DVR Settings, and scroll to the bottom of this list to look for this option:
If that is enabled, let’s see if you disabled it for the recording itself.
  • If you have a recording scheduled (for an entire series), then go to Live TV & DVR on the left-hand side of your normal library side-bar.
  • Along the top, click DVR Schedule to see your list of recordings. On the right-hand side, find the show that didn’t do commercial skip and click it.
  • In the bottom left, click Show Advanced.
  • Scroll to almost the bottom, and look for this setting:
Is it enabled there too?
Yes. I’m not certain why I’m being asked several times if it’s enabled.
Why would I disable it if I was testing to make sure it works. The ONLY thing I’m testing (and diagnosing) at this point is commercial skip.
Like I’ve said 3 times, the xml is created and there are several commercial spans in there.
It’s in the library as Ad Detection: “At all times”
And the DVR settings to create markers for skipping.
I may have just a few posts here but don’t underestimate my understanding of how commercial skip works. I’ve been involved in the scene since the days of Windows Media Center and DVRMS-Toolbox.
There is something very wrong here and logs should be studied to ascertain a solution or how to go about finding this error/bug.
I also made a new library as other posts have suggested with the “Plex Media Shows” as the agent.
No success on that one either. Still no graphic to skip ads.
We cannot discern your level of technical competency from two sentences asking why Comm Skip isn’t working on “fire stick”. I did find it strange you keep mentioning the XML (which one?), but I didn’t want to “assume” Master’s-degree-level of skill based on that alone. There has been one other person’s post here asking if it was enabled, and you brushed off the “is it enabled?” question by stating that it was scanning.
I am just trying to assist you by having you confirm that you did the basics of troubleshooting, which solve 99% of problems people have on these forums. At this point, it’d likely require a dev to analyze server logs to determine why a finished file is not getting marked with comm skip markers.
Edit: Just had a thought: The XML you are referring to, is the xml text you referring to the one you see by clicking Get Info on a recorded item? If it is showing up here, then
 hmm, even stranger than I thought. Have you tried the item in any other player to see if the comm skip function works at all? Web, iOS, Plex-for-Windows, etc.
Android (my phone) doesn’t work, if anything actually works, I’ll edit this post.
Someone else mentioned that the xml is supposed to be deleted after it goes into the database for the show.
The format is:
My Show (2000).ts
My Show (2000).xml
You were asking which xml it is.
There was a problem with tuners in this computer a while ago, I would guess that’s when the dB started to get ‘messed up’
I erased an xTeVe tuner and it wouldn’t come back unless I changed the port number for xTeVe.
I’ll also let you know that “Live TV & DVR” is NOT what I see. It is ONLY “Live TV”. I suspect that Plex’s dB needs a fix.
I mentioned the xml would be deleted, but seeing an actual .xml file in your file explorer is odd. Aside from the “.grab” folder, Plex has not written anything to my media library location other that DVR items. So if you are referring to an actual .xml file, is it alongside the file itself, in your media folder? Or are you looking at it while it is still in the temp “.grab” folder? Or is it in the “/tmp/” folder in the server data files?
Seeing “Live TV” instead of “Live TV & DVR” makes me think that one of two things are happening.
  1. You are running an old Plex server version? I don’t remember if they changed the menu, but not having “& DVR” could be what it used to be long ago. I realized I hadn’t checked if you are keeping Plex up to date, or if you use an older version.
  2. Your DVR is
 not being detected? I think it’s possible the menu option can be “Live TV” if Plex does not detect a DVR connected to it. I have had my DVR connected for 2 years now, so I wouldn’t be able to tell unless I removed it, which I cannot afford to things mess up by doing myself.
The xml is alongside the TS file in the show’s folder structure, NOT in .grab
Server version: 1.31.2.6810 (I just checked for updates and that’s all high as it goes for now.)
I am guessing the “Live TV & DVR” started with issues I had in the past (a year ago) was when I had the issue deleting it and setting it back up, which was done WITHOUT a Plex Pass.
Any idea how to wipe the DVR parts from the Database?
I’m on a slightly higher version, but at least you aren’t 1-2 years out of date.
Strange to find the com-skip xml alongside the file in the media library itself. Something tells me then that your server isn’t finishing the post-record process. Do you have a custom post-processing script that is ran after a recording? I doubt that is the issue, since the file is making it out of the .grab folder and into the base media folder, but I figure I’d check.
I know of no way to repair any entries related to the DVR in the database. I think maybe the preferences.xml file in the Plex data folder that Plex loads might have bad entries in it, but I don’t know what to look for or delete. Let’s ping @ChuckPa (sorry pal, you’re the only dev I know :wink:) who might be able to help out more.
You must be on a beta version?
I don’t think I do betas
 I am on a docker, doing the “:Plexpass” build, which might get releases sooner than non-pass users. I never thought about that being a beta branch.
No PlexPass build for Windows
 All I see is public and beta
I really wonder if my browser cache has something stuck where it looks like I don’t have a PlexPass
I’ll beat the hell out of the control-f5 button to see if it helps :wink:
Try checking the XML info (click that link for information on how to view it) to see if the commercial markers are actually being written to the database. This isn’t a physical file; it’s dynamically generated from the Plex database whenever the “View XML” link is clicked after viewing an item’s info via “Get Info.”
If commercial markers have been correctly generated and added to the database for an item, you’ll see XML data similar to the following toward the bottom of the file.
<Marker id="1709" type="commercial" startTimeOffset="0" endTimeOffset="5710">
<Attributes id="1709"/>
</Marker>
<Marker id="1709" type="commercial" startTimeOffset="356520" endTimeOffset="571670">
</Marker>
<Marker id="1709" type="commercial" startTimeOffset="1622190" endTimeOffset="1817520">
</Marker>
<Marker id="1709" type="commercial" startTimeOffset="2242110" endTimeOffset="2317580">
</Marker>
<Marker id="1709" type="commercial" startTimeOffset="2806470" endTimeOffset="3027120">
</Marker>
<Marker id="1709" type="commercial" startTimeOffset="3345980" endTimeOffset="3416150">
</Marker>
<Marker id="1709" type="commercial" startTimeOffset="3547610" endTimeOffset="3598930">
</Marker>
<Marker id="1709" type="intro" startTimeOffset="254285" endTimeOffset="353910">
</Marker>
If you do not see similar entries, the commercial detection process is failing somewhere along the line; I suspect it is since you’re left with a “Show Name.xml” file. As stated previously, that should not survive the process.
My commercial xml looks like a traditional comskip xml, nowhere in there does it say anything about markers.
version="end=“84.400986” start=“0.000000”/>
<commercial end= end=“1603.802203” =“1057.372986”/>
Also, I just made a DVR on another server on my account, it still doesn’t say “Live TV & DVR” ANYWHERE on my account EXCEPT settings where you create the DVR.
There sure isn’t a Live TV & DVR on that server in the more screen.
The ONLY way I can get to my guide is to press Live TV in the Plex area at the bottom of the more screen.
Is there a problem with my account?
Did you check whether you had markers in your database using the instructions I provided? The XML file you’re referring to shouldn’t be there. Its presence indicates some likely failure. The directions above will let you see if the markers ever made it into the database.
And it is completely normal to see just “Live TV” now, if you have Plex’s “Live TV” source enabled (it is by default). If it’s enabled, Plex’s live TV “channels” and your DVR’s are aggregated under once view, Live TV, in clients.
Good to know about the “Live TV” thing.
No markers as far as I can see but you can take a look at this test recording (that has a robust commercial xml).
