Confused about "Album Genre"
Server Version#: 1.24.3.5033
Greetings,
I am confused about how Plex handles music genres. I sort my music after genre, and I use mp3tag to fix the tags of my files. For example, I have a Trance folder and all of the (mp3) tracks there have the genre Trance. But then when I try to sort the tracks in Plex by this tag, I only find “Album Genre” and “Artist Genre”. And the selection is incorrect, for example if I have 100 tracks in the folder, Plex finds more than 100, so it must pull that data from somewhere.
I configured the library and agents to only look for local metadata, so it doesn’t search for data on the internet.
Given Plex doesn’t derive genre information from a folder structure… could it be as simple as files from other folders also having an Trance genre tag?
Yes, the Trance tag is derived from the ID3 tag embedded in the file. However the standard ID3 tag only has “Genre” and not “Album Genre” or “Artist Genre”. I believe that “Album Genre” is “Genre”, not sure about the other.
Ok so I re-added the library with the following settings:
  • plex music scanner
  • personal media artists
  • prefer local metadata
  • genres is set to embedded tags
All the files are checked to have the correct id3 tag. If I then create a filter:
  • match all of the following
  • album genre is “techno” - 177 tracks out of 182
  • artist genre is “techno” - 201 tracks out of 182
I can see tracks that don’t have the genre tag set to “techno”.
The point here is to create smart playlists based on the genre tag.
Don’t. These scanners and agents are deprecated and are no longer supported.
“Plex Music” is supported.
After creating the library, don’t start the scan immediately.
Go to the “Advanced” tab and set “Genres” to “Embedded tags”.
Ok so I did just that and it’s still a mess. For some reason, now the tag isn’t pulled from some tracks. Not only that, but I discovered that Plex actually looks for an “album genre”, which in my opinion is wrong. If I try to edit a single track, I don’t get the genre tag, but if I try to edit the entire album, I do. Genres are track specific, not album specific, so why does Plex do this?
Anyway, an example of a tag not being pulled:
Notice that there’s no genre. But here’s the file metadata:
3
