That looks about right yeah. After I ran some tests to figure out the optimal bs but yeah. I did a little research that said that should be fine but you know the internet so I may have been led astray.
Yep thats probably pretty accurate as to what I did to clone the drive. I think my bs was bigger but I dont recall the command I used to be honest but I believe I used the page here:
Where you show 1.3TB in use. you gotta fsck and fix that .
Did you copy the file system LIVE (while it was running) ?
Having a sneaking suspicion that the i/o wait is getting sucked up because Linux’s free block list is all hosed up. (It’s looking for blocks down a 500GB long list of unaccounted for pages)
I did not- I did a USB disc and did it from there I just finished a fsck and it did make some modifications. Didn’t take too long but It was saying there was a number of optimizations to make so I let it do them. Lets see how it looks now
The dd rate must be the spec of your SSD. My SSD is a Samsung. This one does about 2.5-2.7 and my other Samsung does 3.5. It all depends on the tech used.
Not wasting more effort on the raw perf. 1.5/1.6 is good enough for now.
If the IOwait is down – GOOD. that’ll go a long way.
How does PMS behave now? A bit crisper loading up sections?
The sections seem to load fine but im still getting buffering issues across multiple episodes which are on multiple different drives which I wasn’t getting until a couple weeks ago.
