content loading error
hi when i open trailers on apple tv3 plex show me screen like this http://i.imgur.com/gJglhnF.jpgand cant open any video when i try to open some video then plex stuck at accessing trailers
i had no problem before
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.0.12
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 192.168.0.12
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = Normal
logpath = .
Looks like your PMS not accepting requests from outside your computer... need more info like local IP addresses and log.
@baa thanks for reply.
where is the log file?
Typically in the PlexConnect installation directory, called PlexConnect.log.
Setting loglevel=High in Settings does help figuring out most issues as well.
See also: https://forums.plex.tv/topic/69410-read-before-posting/
here is log file https://fnpaste.com/Qnq9
aTV: 192.168.0.10
PlexConnect: 192.168.0.12
PMS: 192.168.56.1
PMS seems to live in a different subnet - that way aTV might not be able to access data directly.
Should PlexConnect/PMS run on the same machine? Do you have multiple network cards installed - like LAN and WiFi?
@Baa
i did disable other network connections (http://i.imgur.com/PNMGFbl.png) and now it works! thanks!!
