Continuous play on Rasplex
Hi all,
I’ve got Rasplex running with a Logitech harmony touch, just wondering if there’s any way to do a play all when watching TV shows? I heard mapping ‘p’ would achieve this on some clients but wasn’t sure about Rasplex.
If you select a show and then open the Context Menu and select ‘Play from here’ it will play all the shows in order until you press Stop.
Regards
Just mapped the menu button my harmony to contextmenu and that works great, thanks
