Conversion failed. A required codec could not be found or failed to install after update
Server Version#: 1.25.0.5282
Player Version#: 4.66.1
I just updated from 1.24.something to 1.25.0.5282
When I try to play any file I get the message “Conversion failed. A required codec could not be found or failed to install”
On V1.24.x it worked fine.
One thing I notice is that in the Settings under General I get this message:
Version 1.25.0.5282 An update is available. Please install manually.
When I follow the link, it takes me to 1.25.0.5282
I am running Synology DSM 7.0.1-42218 with an Intel chip, 64 bit so that’s the image I installed.
I checked the logs and I’m getting some new errors I wasn’t getting right before the update.
Dec 01, 2021 08:40:32.378 [0x7fd876964b38] ERROR - [MediaProviderManager] Error issuing curl_easy_perform(handle): 6
Dec 01, 2021 08:40:32.378 [0x7fd876964b38] WARN - [MediaProviderManager] HTTP error requesting GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (6, Couldn’t resolve host name) (Could not resolve host: plex.tv)
Dec 01, 2021 08:40:32.378 [0x7fd876964b38] ERROR - [MediaProviderManager] Error parsing content.
Dec 01, 2021 08:40:32.378 [0x7fd876964b38] ERROR - [MediaProviderManager] Error parsing XML: Error parsing file.
OK. You can ignore this. I had installed a new router and the IP address was different. My Synology NAS had the default gateway set up wrong. What’s interesting is that, even with the new router, Plex worked until I did the update. Some network setting must have persisted for a while until the forced restart of the Plex server.
