Conversion failed. A required codec could not be found or failed to install April 2022
Server Version#: 4.76.1
I am seeing many of the same issues others in this thread have had. Cannot play MVK files anymore, and going back to previous versions doesn’t resolve the issue.
Noticed the following “easyaudioencoder” errors in the logs.
"Apr 28, 2022 15:25:39.396 [0x809b73600] DEBUG - [Transcode] Found session GUID of 538ujyh31sbs6yqqxdzqz700 in session start.
Apr 28, 2022 15:25:39.397 [0x809b73600] DEBUG - [Transcode] TranscodeUniversalRequest: adapting profile with augmentation data: append-transcode-target-codec(type=videoProfile&context=streaming&audioCodec=aac&protocol=dash)
Apr 28, 2022 15:25:39.397 [0x809b73600] DEBUG - [Transcode] TranscodeUniversalRequest: using augmented profile Web
Apr 28, 2022 15:25:39.397 [0x809b73600] DEBUG - [Transcode] Downloading document http://127.0.0.1:32400/library/metadata/65417?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=2t08dcdesmmpxxjuuh9wh93g
Apr 28, 2022 15:25:39.402 [0x809b73600] DEBUG - [Transcode] We’re going to try to auto-select an audio stream for account 1.
Apr 28, 2022 15:25:39.402 [0x809b73600] DEBUG - [Transcode] Selecting best audio stream for part ID 120117 (autoselect: 0 language: en)
Apr 28, 2022 15:25:39.402 [0x809b73600] DEBUG - [Transcode] Audio Stream: 290146, Subtitle Stream: -1
Apr 28, 2022 15:25:39.403 [0x809b73600] DEBUG - [Transcode] Found session GUID of 538ujyh31sbs6yqqxdzqz700 in session start.
Apr 28, 2022 15:25:39.403 [0x809b73600] DEBUG - [Transcode] Cleaning directory for session 538ujyh31sbs6yqqxdzqz700 ()
Apr 28, 2022 15:25:39.403 [0x809b73600] DEBUG - [Transcode] Starting a transcode session 538ujyh31sbs6yqqxdzqz700 at offset -1.0 (state=3)
Apr 28, 2022 15:25:39.404 [0x809b73600] DEBUG - [Transcode] TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Apr 28, 2022 15:25:39.404 [0x809b73600] INFO - [Transcode] CodecManager: obtaining EAE
Apr 28, 2022 15:25:39.404 [0x809b73600] DEBUG - [Transcode] HTTP requesting GET https://plex.tv/api/codecs/easyaudioencoder?build=freebsd-x86_64-standard&deviceId=4e9ab258-114f-4ed0-a141-45042375c23e&oldestPreviousVersion=1.15.3.858-fbfb913f7&version=1785
Apr 28, 2022 15:25:39.594 [0x80989d000] DEBUG - [HttpClient] HTTP/2.0 (0.2s) 429 response from GET https://plex.tv/api/codecs/easyaudioencoder?build=freebsd-x86_64-standard&deviceId=4e9ab258-114f-4ed0-a141-45042375c23e&oldestPreviousVersion=1.15.3.858-fbfb913f7&version=1785 (reused)
Apr 28, 2022 15:25:39.594 [0x809b73600] ERROR - [Transcode] Codecs: Failed to download XML for codec 'easyaudioencoder’
Apr 28, 2022 15:25:39.594 [0x809b73600] ERROR - [Transcode] Error configuring transcoder: Decoder install failed: eac3_eae
Apr 28, 2022 15:25:39.594 [0x809b73600] DEBUG - [Transcode] Streaming Resource: Terminating session 0x810255558:2t08dcdesmmpxxjuuh9wh93g which is using transcoder slot. Used slots is now 0
Apr 28, 2022 15:25:39.594 [0x809b73600] DEBUG - [Transcode] Streaming Resource: Terminated session 0x810255558:2t08dcdesmmpxxjuuh9wh93g with reason Conversion failed. A required codec could not be found or failed to install.
Apr 28, 2022 15:25:39.595 [0x80a43b000] DEBUG - [Transcode] Killing job.
Apr 28, 2022 15:25:39.595 [0x80a43b000] DEBUG - [Transcode] Job was already killed, not killing again.
Apr 28, 2022 15:25:39.595 [0x80a43b000] DEBUG - [Transcode] Stopping transcode session 538ujyh31sbs6yqqxdzqz700
Apr 28, 2022 15:25:39.595 [0x80dc51500] DEBUG - [Transcode] Cleaning directory for session 538ujyh31sbs6yqqxdzqz700 (/config/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-538ujyh31sbs6yqqxdzqz700-8302f27f-6445-41d2-85d5-fe091eeb1152)
Apr 28, 2022 15:25:39.595 [0x807af0800] DEBUG - Completed: [192.168.10.20:62522] 404 GET "
I have read every forum post on this matter, and it doesnt appear to be DNS related as I can resolve that URL. Permissions have not changed either.
Getting the exact same thing. Guessing there’s a server issue going on at Plex.
HTTP error code 429 means there has been too many attempts to access the resource in a certain length of time. AKA rate limited.
Try again later.
That XML file pulls up for me in the browser.
Thank you @kryndis for confirming. I’ve spent too many hours troubleshooting everything today, so it’s good to know it’s not just me. Appreciate the info on the retries @kegbeach
@kryndis playback randomly just started working for me, after being down for 1.5 days. So hopefully it’s working for you now too!
@cadocomp Still no joy here, but hopefully this means whatever the problem is is being resolved.
Stop trying to use media that requires that codec for a while. You’re being rate limited for trying too often.
What’s interesting is that we don’t watch much on Plex, and our viewing habits haven’t changed in the past 6 years of using Plex. We did recently change our ISPs from Xfinity to T-Mobile Home 5G the day before I noticed this issue. I’m curious if the codec servers see this traffic coming from “cell carrier addresses” and is doing some kind of rate limiting.
The issue came back after allowing us to play the first few mins of a show, so we are back in the same situation as before now.
That is totally possible since cell carrier public IP’s are shared among many users so it makes sense…
Good news is that once the updated codec is downloaded you should be good to go for a while…
