Conversion failed. A required codec could not be found or failed to install
Server Version#: Version 1.18.8.2527
Player Version#: Version 4.22.2
Running in a docker on unraid.
When in the chrome player, some files play, some do not. The higher bitrate files return:
Conversion failed. A required codec could not be found or failed to install.
All these same files are able to play back on the android app (have not tested any other players).
Please advise.
On Android plex player it only plays original format.
Transcoding down results in the same error.
I have the same error still looking for any help.
Is it possible for someone to manually upload their codecs so I can copy them into my folder?
Formatting SSD in XFS solved isssue.
