Conversion failed. a required codec could not be found or failed to install
Server Version#: v1.18.7.2457-77cb9455c
Player Version#: 4.22.2
Got this issue after updating. rolled back. But that didn’t Work. Already looked at logs the relevant lines are below.
Mar 21, 2020 17:00:10.079 [0x7fe16e88f700] WARN - HTTP error requesting GET https://plex.tv/api/codecs/h264_decoder?build=linux-x86_64-standard&deviceId=748ec2e8-dbf3-4512-84b8-06bce366a684&oldestPreviousVersion=1.18.3.2156-349e9837e&version=0bc617e-2965 (0, No error) (Could not resolve host: plex.tv)
Mar 21, 2020 17:00:10.079 [0x7fe16e88f700] ERROR - Codecs: Failed to download XML for codec ‘h264_decoder’
Mar 21, 2020 17:00:10.079 [0x7fe16e88f700] ERROR - Error configuring transcoder: Decoder install failed: h264
Mar 21, 2020 17:00:10.079 [0x7fe16e88f700] DEBUG - Streaming Resource: Terminated session 0x7fe168029f30:2afko9kef6yc2sxngu6kxkuz with reason Conversion failed. A required codec could not be found or failed to install.
check default gateway on the NAS
Verify the Syno can reach the internet successfully.
If in a VM or container, verify within the confines of that abstraction as well.
The error is as it seems: It cannot resolve (lookup the IP address of) plex.tv
