Operating System: Ubuntu 20.04.2 LTS
Kernel: Linux 5.8.0-53-generic
(no docker or any other containers)
Plex version: 1.23.2.4584-bdefd2026
(previous version worked fine and if I could find a previous version I’d probably roll back but plex doesn’t list old versions [please please fix this]) Plex has access to all folders in var/lib.
After the upgrade, I am getting an error for playback on Android and Chrome. Here are the error logs.
May 25, 2021 20:10:01.515 [0x7efe3cd74b38] Info — [Transcode] CodecManager: obtaining decoder ‘h264’
May 25, 2021 20:10:06.519 [0x7efe3cd74b38] Error — [Transcode] Error issuing curl_easy_perform(handle): 6
May 25, 2021 20:10:06.519 [0x7efe3cd74b38] Error — [Transcode] Codecs: Failed to download XML for codec ‘h264_decoder’
May 25, 2021 20:10:06.520 [0x7efe3cd74b38] Error — [Transcode] Error configuring transcoder: Decoder install failed: h264
May 25, 2021 20:10:10.322 [0x7efe3c9a9b38] Info — [Transcode] CodecManager: obtaining decoder ‘h264’
May 25, 2021 20:10:14.559 [0x7efe3ba9db38] Error — [MediaProviderManager] Error issuing curl_easy_perform(handle): 6
May 25, 2021 20:10:14.560 [0x7efe3ba9db38] Error — [MediaProviderManager] Error parsing content.
May 25, 2021 20:10:14.560 [0x7efe3ba9db38] Error — [MediaProviderManager] Error parsing XML: Error parsing file.
May 25, 2021 20:10:15.327 [0x7efe3c9a9b38] Error — [Transcode] Error issuing curl_easy_perform(handle): 6
May 25, 2021 20:10:15.327 [0x7efe3c9a9b38] Error — [Transcode] Codecs: Failed to download XML for codec ‘h264_decoder’
May 25, 2021 20:10:15.328 [0x7efe3c9a9b38] Error — [Transcode] Error configuring transcoder: Decoder install failed: h264
May 25, 2021 20:10:16.467 [0x7efe3c9a9b38] Error — SQLITE3:0x80000001, 28, double-quoted string literal: “2021-05-04 19:05:25”
May 25, 2021 20:10:16.780 [0x7efe3cd74b38] Error — SQLITE3:0x80000001, 28, double-quoted string literal: “2021-05-04 19:05:25”
May 25, 2021 20:10:21.343 [0x7efe3bf39b38] Error — Error issuing curl_easy_perform(handle): 6
May 25, 2021 20:11:01.350 [0x7efe3cd74b38] Error — Sync: could not get sync list 56182914, sync item 47052210 to update status
I can nslookup plex.tv fine, network is fine and I am trying to play on my own network.
