Conversion failed. The transcoder exited due to an error on web browser and chromsecast, but not iOS
Server Version#: 1.25.2.5319
Web Player Version#: 4.72.1
iOS Player Version#: 7.27
Hello!
I recently installed PMS in a Docker Container on a Linux (Ubuntu 21.10) server. A handful of my movies are throwing the error “Conversion failed. The transcoder exited due to an error.” when I try to watch them either in the web player or casted to a Chromecast from my iPhone. The problem movies will work fine when I watch them in the iOS app though, and it’s only certain movies, not all of them.
I tried taking a look at the other forum posts with the same error, but there seemed to a wide range of root causes and I wasn’t able to figure out mine when I took a peak at the logs.
Any help is greatly appreciated! Here is a copy of my logs:
Plex Media Server Logs_2022-01-18_04-42-13.zip (927.0 KB)
Either the VC1 codec is damaged or the media is.
index=1&id=0&codec=ac3&type=audio (12 live) Signed-in Token (jrkohlmeyer19@gmail.com) (range: bytes=0-)
Jan 18, 2022 03:45:29.192 [0x7fe125d53b38] DEBUG - Completed: [127.0.0.1:50554] 200 PUT /video/:/transcode/session/aczeam5ds5wnc1sp0nqxudtx/dbaea568-7be0-49d4-a3da-4ca28f869046/progress/stream?index=1&id=0&codec=ac3&type=audio (12 live) 0ms 195 bytes (pipelined: 6) (range: bytes=0-)
Jan 18, 2022 03:45:29.194 [0x7fe12502db38] ERROR - [Transcoder] [vc1 @ 0x7efd288295c0] Incomplete extradata
Jan 18, 2022 03:45:29.195 [0x7fe12502db38] DEBUG - Request: [127.0.0.1:50554 (Loopback)] PUT /video/:/transcode/session/aczeam5ds5wnc1sp0nqxudtx/dbaea568-7be0-49d4-a3da-4ca28f869046/progress/streamDetail?index=0&id=0&codec=vc1&type=video&width=1920&height=796&interlaced=0&frameRate=23.976&disp_default=1 (12 live) Signed-in Token (jrkohlmeyer19@gmail.com) (range: bytes=0-)
Jan 18, 2022 03:45:29.195 [0x7fe125d53b38] DEBUG - Completed: [127.0.0.1:50554] 200 PUT /video/:/transcode/session/aczeam5ds5wnc1sp0nqxudtx/dbaea568-7be0-49d4-a3da-4ca28f869046/progress/streamDetail?index=0&id=0&codec=vc1&type=video&width=1920&height=796&interlaced=0&frameRate=23.976&disp_default=1 (12 live) 0ms 195 bytes (pipelined: 9) (range: bytes=0-)
Jan 18, 2022 03:45:29.195 [0x7fe12502db38] DEBUG - Request: [127.0.0.1:50554 (Loopback)] PUT /video/:/transcode/session/aczeam5ds5wnc1sp0nqxudtx/dbaea568-7be0-49d4-a3da-4ca28f869046/progress/streamDetail?index=1&id=0&codec=ac3&type=audio&bitrate=640000&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000&disp_default=1 (12 live) Signed-in Token (jrkohlmeyer19@gmail.com) (range: bytes=0-)
Jan 18, 2022 03:45:29.196 [0x7fe125d53b38] DEBUG - Completed: [127.0.0.1:50554] 200 PUT /video/:/transcode/session/aczeam5ds5wnc1sp0nqxudtx/dbaea568-7be0-49d4-a3da-4ca28f869046/progress/streamDetail?index=1&id=0&codec=ac3&type=audio&bitrate=640000&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000&disp_default=1 (12 live) 0ms 195 bytes (pipelined: 10) (range: bytes=0-)
Jan 18, 2022 03:45:29.197 [0x7fe12502db38] DEBUG - Request: [127.0.0.1:50554 (Loopback)] PUT /video/:/transcode/session/aczeam5ds5wnc1sp0nqxudtx/dbaea568-7be0-49d4-a3da-4ca28f869046/progress?duration=9141.536000 (12 live) Signed-in Token (jrkohlmeyer19@gmail.com) (range: bytes=0-)
Jan 18, 2022 03:45:29.197 [0x7fe125af0b38] DEBUG - [Transcode] Started session successfully: aczeam5ds5wnc1sp0nqxudtx
Jan 18, 2022 03:45:29.197 [0x7fe125d30b38] DEBUG - Completed: [127.0.0.1:50554] 204 PUT /video/:/transcode/session/aczeam5ds5wnc1sp0nqxudtx/dbaea568-7be0-49d4-a3da-4ca28f869046/progress?duration=9141.536000 (12 live) 0ms 203 bytes (pipelined: 11) (range: bytes=0-)
Jan 18, 2022 03:45:29.197 [0x7fe12502db38] ERROR - [Transcoder] [vc1 @ 0x7efd287dcb80] Incomplete extradata
Jan 18, 2022 03:45:29.197 [0x7fe12502db38] ERROR - [Transcoder] Error while opening decoder for input stream #0:0 : Invalid data found when processing input
Jan 18, 2022 03:45:29.198 [0x7fe125d30b38] DEBUG - Completed: [192.168.86.32:56525] 200 GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F138&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=aczeam5ds5wnc1sp0nqxudtx&subtitles=burn&Accept-Language=en (12 live) TLS GZIP 29ms 1079 bytes (pipelined: 10)
Jan 18, 2022 03:45:29.198 [0x7fe126f8eb38] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 496 is 1 (failure)
Jan 18, 2022 03:45:29.199 [0x7fe124fe1b38] DEBUG - Streaming Resource: Terminating session 0x7fe1253e09a8:3tx3sj64v2qxsfwoktpf4kv1 which is using transcoder slot.  Used slots is now 0
Jan 18, 2022 03:45:29.199 [0x7fe125073b38] DEBUG - Killing job.
Jan 18, 2022 03:45:29.199 [0x7fe125073b38] DEBUG - Signalling job ID
File: ‘/Media/Movies/Harry Potter and the Sorcerer’’‘s Stone (2001)/Harry Potter and the Sorcerer’’‘s Stone (2001).mkv’
