Conversion failed. The transcoder exited due to an error
Server Version#: 1.13.5.5332-21ab172de
Player Version#: Various: Amazon Fire Stick, Android
I’m not sure where to report I have “Network interface to listen on” set to All things works fine. When it’s set to the only other option br0 (192.168.x.x) I get the transcoding error above.
I’m using a Coffee Lake i3 with the libva 2.2.1 built from source so it uses HW transcoding.
Not sure I can do anything else to help
Can you make sure you have DEBUG logging enabled (not VERBOSE) and do the following ?
  1. Start playback
  2. When it fails, wait 30 seconds for it to clean up and write to the logs
  3. Gather the logs (Settings - Server - Help - Download Logs)
  4. Get the XML (Hover over the item being played -> Get Info (under the ellipsis) -> View XML)
  5. Attach both with your next reply.
Here you go, thanks for looking into it.Plex Media Server Logs_2018-08-30_10-37-22.zip (65.4 KB)
8648.xml.txt (3.0 KB)
(I had to rename the xml to .xml.txt to upload)
Thanks!
Edit: I don’t think the issue is with the file type as it happens with any file. Even when playing on the same LAN.
