Transcoder errors after updating
I updated my server today and after doing so the logs were immediately filled with these entries and users were not able to connect.
I’ve been noticing over the past few months as well that the web UI stream indicator in the top left takes a very long time to populate at times - this usually coincides with the server timing out, effectively crashing.
Server Version#: 1.23.2.4656
Player Version#: N/A
 ERROR - [Transcode] XML: Entity: line 1:
	Line 16641: Jun 05, 2021 23:39:36.712 [0x7f0d427efb38] ERROR - [Transcode] XML: parser
	Line 16642: Jun 05, 2021 23:39:36.712 [0x7f0d427efb38] ERROR - [Transcode] XML: error :
	Line 16643: Jun 05, 2021 23:39:36.712 [0x7f0d427efb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16644: Jun 05, 2021 23:39:36.712 [0x7f0d427efb38] ERROR - [Transcode] XML: #sub-chunk-00000,0.000000,0.000000,0.000000,0.000000
	Line 16645: Jun 05, 2021 23:39:36.712 [0x7f0d427efb38] ERROR - [Transcode] XML: ^
	Line 16646: Jun 05, 2021 23:39:36.712 [0x7f0d427efb38] ERROR - [Transcode] Error parsing content.
	Line 16647: Jun 05, 2021 23:39:36.712 [0x7f0d427efb38] ERROR - Exception handled: Error parsing file
	Line 16693: Jun 05, 2021 23:39:37.399 [0x7f0d42b6eb38] ERROR - SQLITE3:0x80000001, 28, double-quoted string literal: "2021-05-22 23:39:37"
	Line 16721: Jun 05, 2021 23:39:37.724 [0x7f0d44affb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16722: Jun 05, 2021 23:39:37.724 [0x7f0d44affb38] ERROR - [Transcode] XML: parser
	Line 16723: Jun 05, 2021 23:39:37.724 [0x7f0d44affb38] ERROR - [Transcode] XML: error :
	Line 16724: Jun 05, 2021 23:39:37.724 [0x7f0d44affb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16725: Jun 05, 2021 23:39:37.724 [0x7f0d44affb38] ERROR - [Transcode] XML: sub-chunk-00000,0.000000,12.074000,0.000000,0.000000
	Line 16726: Jun 05, 2021 23:39:37.724 [0x7f0d44affb38] ERROR - [Transcode] XML: ^
	Line 16727: Jun 05, 2021 23:39:37.724 [0x7f0d44affb38] ERROR - [Transcode] Error parsing content.
	Line 16728: Jun 05, 2021 23:39:37.724 [0x7f0d44affb38] ERROR - Exception handled: Error parsing file
	Line 16729: Jun 05, 2021 23:39:37.724 [0x7f0d4474fb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16730: Jun 05, 2021 23:39:37.724 [0x7f0d4474fb38] ERROR - [Transcode] XML: parser
	Line 16731: Jun 05, 2021 23:39:37.724 [0x7f0d4474fb38] ERROR - [Transcode] XML: error :
	Line 16732: Jun 05, 2021 23:39:37.724 [0x7f0d4474fb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16733: Jun 05, 2021 23:39:37.724 [0x7f0d4474fb38] ERROR - [Transcode] XML: sub-chunk-00000,0.000000,12.074000,0.000000,0.000000
	Line 16734: Jun 05, 2021 23:39:37.724 [0x7f0d4474fb38] ERROR - [Transcode] XML: ^
	Line 16735: Jun 05, 2021 23:39:37.725 [0x7f0d4474fb38] ERROR - [Transcode] Error parsing content.
	Line 16736: Jun 05, 2021 23:39:37.725 [0x7f0d4474fb38] ERROR - Exception handled: Error parsing file
	Line 16773: Jun 05, 2021 23:39:38.381 [0x7f0d42c7ab38] DEBUG - [Transcode/upqjor6g7ct4vwtkun9iam9o/JobRunner] Job running: EAE_ROOT='/tmp/pms-82f6e355-34c7-446f-8436-d8d7106fba04/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/fa235d6-3858-linux-x86_64/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/usr/lib/plexmediaserver/Plex Transcoder' '-codec:0' 'h264' '-codec:1' 'eac3_eae' '-eae_prefix:1' 'upqjor6g7ct4vwtkun9iam9o_' '-ss' '3525' '-analyzeduration' '20000000' '-probesize' '20000000' '-i' '/mnt/Echo/Movies/The Conjuring The Devil Made Me Do It (2021)/The Conjuring The Devil Made Me Do It (2021)-WEBDL-1080p.mkv' '-ss' '3525' '-analyzeduration' '20000000' '-probesize' '20000000' '-i' '/mnt/Beta/Transcode/Sessions/plex-transcode-upqjor6g7ct4vwtkun9iam9o-200573db-d894-4f0a-b1b3-4463058eb3e4/temp-0.srt' '-filter_complex' '[0:0]scale=w=1280:h=544[0];[0]format=pix_fmts=yuv420p|nv12[1]' '-map' '[1]' '-codec:0' 'libx264' '-crf:0' '22' '-maxrate:0' '3368k' '-bufsize:0' '6736k' '-r:0' '23.975999999999999' '-preset:0' 'veryfast' '-level:0' '5.1' '-x264opts:0' 'subme=2:me_range=4:rc_lookahead=10:me=hex:8x8dct=1' '-force_key_frames:0' 'expr:gte(t,n_forced*5)' '-filter_complex' '[0:1] aresample=async=1:ocl='\''5.1'\'':rematrix_maxval=0.000000dB:osr=48000[2]' '-map' '[2]' '-metadata:s:1' 'language=eng' '-codec:1' 'aac' '-b:1' '414k' '-f' 'dash' '-seg_duration' '5' '-init_seg_name' 'init-stream$RepresentationID$.m4s' '-media_seg_name' 'chunk-stream$RepresentationID$-$Number%05d$.m4s' '-window_size' '5' '-delete_removed' 'false' '-skip_to_segment' '706' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/upqjor6g7ct4vwtkun9iam9o/200573db-d894-4f0a-b1b3-4463058eb3e4/manifest?X-Plex-Http-Pipeline=infinite' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'dash' '-map' '1:s:0' '-metadata:s:0' 'language=eng' '-codec:0' 'copy' '-f' 'segment' '-segment_format' 'srt' '-segment_time' '1' '-segment_hea ...
	Line 16830: Jun 05, 2021 23:39:38.923 [0x7f0d4485bb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16831: Jun 05, 2021 23:39:38.923 [0x7f0d4485bb38] ERROR - [Transcode] XML: parser
	Line 16832: Jun 05, 2021 23:39:38.923 [0x7f0d4485bb38] ERROR - [Transcode] XML: error :
	Line 16833: Jun 05, 2021 23:39:38.923 [0x7f0d4485bb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16834: Jun 05, 2021 23:39:38.923 [0x7f0d4485bb38] ERROR - [Transcode] XML: sub-chunk-00000,0.000000,3525.033000,0.000000,0.000000
	Line 16835: Jun 05, 2021 23:39:38.923 [0x7f0d4485bb38] ERROR - [Transcode] XML: ^
	Line 16836: Jun 05, 2021 23:39:38.924 [0x7f0d4485bb38] ERROR - [Transcode] Error parsing content.
	Line 16837: Jun 05, 2021 23:39:38.924 [0x7f0d42b6eb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16838: Jun 05, 2021 23:39:38.924 [0x7f0d42b6eb38] ERROR - [Transcode] XML: parser
	Line 16839: Jun 05, 2021 23:39:38.924 [0x7f0d42b6eb38] ERROR - [Transcode] XML: error :
	Line 16840: Jun 05, 2021 23:39:38.924 [0x7f0d42b6eb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16841: Jun 05, 2021 23:39:38.924 [0x7f0d42b6eb38] ERROR - [Transcode] XML: #sub-chunk-00000,0.000000,0.000000,0.000000,0.000000
	Line 16842: Jun 05, 2021 23:39:38.924 [0x7f0d42b6eb38] ERROR - [Transcode] XML: ^
	Line 16843: Jun 05, 2021 23:39:38.924 [0x7f0d42b6eb38] ERROR - [Transcode] Error parsing content.
	Line 16844: Jun 05, 2021 23:39:38.924 [0x7f0d4485bb38] ERROR - Exception handled: Error parsing file
	Line 16845: Jun 05, 2021 23:39:38.924 [0x7f0d42b6eb38] ERROR - Exception handled: Error parsing file
	Line 16846: Jun 05, 2021 23:39:38.925 [0x7f0d4129eb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16847: Jun 05, 2021 23:39:38.925 [0x7f0d4129eb38] ERROR - [Transcode] XML: parser
	Line 16848: Jun 05, 2021 23:39:38.925 [0x7f0d4129eb38] ERROR - [Transcode] XML: error :
	Line 16849: Jun 05, 2021 23:39:38.925 [0x7f0d4129eb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16850: Jun 05, 2021 23:39:38.925 [0x7f0d4129eb38] ERROR - [Transcode] XML: sub-chunk-00000,0.000000,3525.033000,0.000000,0.000000
	Line 16851: Jun 05, 2021 23:39:38.925 [0x7f0d4129eb38] ERROR - [Transcode] XML: ^
	Line 16852: Jun 05, 2021 23:39:38.925 [0x7f0d4129eb38] ERROR - [Transcode] Error parsing content.
	Line 16853: Jun 05, 2021 23:39:38.926 [0x7f0d4129eb38] ERROR - Exception handled: Error parsing file
	Line 16874: Jun 05, 2021 23:39:39.954 [0x7f0d42b6eb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16875: Jun 05, 2021 23:39:39.954 [0x7f0d42b6eb38] ERROR - [Transcode] XML: parser
	Line 16876: Jun 05, 2021 23:39:39.954 [0x7f0d42b6eb38] ERROR - [Transcode] XML: error :
	Line 16877: Jun 05, 2021 23:39:39.954 [0x7f0d42b6eb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16878: Jun 05, 2021 23:39:39.954 [0x7f0d42b6eb38] ERROR - [Transcode] XML: sub-chunk-00000,0.000000,3525.033000,0.000000,0.000000
	Line 16879: Jun 05, 2021 23:39:39.954 [0x7f0d42b6eb38] ERROR - [Transcode] XML: ^
	Line 16880: Jun 05, 2021 23:39:39.954 [0x7f0d42b6eb38] ERROR - [Transcode] Error parsing content.
	Line 16881: Jun 05, 2021 23:39:39.955 [0x7f0d42b6eb38] ERROR - Exception handled: Error parsing file
	Line 16882: Jun 05, 2021 23:39:39.956 [0x7f0d44affb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16883: Jun 05, 2021 23:39:39.956 [0x7f0d44affb38] ERROR - [Transcode] XML: parser
	Line 16884: Jun 05, 2021 23:39:39.956 [0x7f0d44affb38] ERROR - [Transcode] XML: error :
	Line 16885: Jun 05, 2021 23:39:39.956 [0x7f0d44affb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16886: Jun 05, 2021 23:39:39.956 [0x7f0d44affb38] ERROR - [Transcode] XML: sub-chunk-00000,0.000000,3525.033000,0.000000,0.000000
	Line 16887: Jun 05, 2021 23:39:39.956 [0x7f0d44affb38] ERROR - [Transcode] XML: ^
	Line 16888: Jun 05, 2021 23:39:39.956 [0x7f0d44affb38] ERROR - [Transcode] Error parsing content.
	Line 16889: Jun 05, 2021 23:39:39.956 [0x7f0d44affb38] ERROR - Exception handled: Error parsing file
	Line 16896: Jun 05, 2021 23:39:40.379 [0x7f0d42c7ab38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16897: Jun 05, 2021 23:39:40.379 [0x7f0d42c7ab38] ERROR - [Transcode] XML: parser
	Line 16898: Jun 05, 2021 23:39:40.379 [0x7f0d42c7ab38] ERROR - [Transcode] XML: error :
	Line 16899: Jun 05, 2021 23:39:40.379 [0x7f0d42c7ab38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16900: Jun 05, 2021 23:39:40.379 [0x7f0d42c7ab38] ERROR - [Transcode] XML: sub-chunk-00000,0.000000,3525.033000,0.000000,0.000000
	Line 16901: Jun 05, 2021 23:39:40.379 [0x7f0d42c7ab38] ERROR - [Transcode] XML: ^
	Line 16902: Jun 05, 2021 23:39:40.379 [0x7f0d42c7ab38] ERROR - [Transcode] Error parsing content.
	Line 16903: Jun 05, 2021 23:39:40.380 [0x7f0d42b6eb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16904: Jun 05, 2021 23:39:40.380 [0x7f0d42b6eb38] ERROR - [Transcode] XML: parser
	Line 16905: Jun 05, 2021 23:39:40.380 [0x7f0d42b6eb38] ERROR - [Transcode] XML: error :
	Line 16906: Jun 05, 2021 23:39:40.380 [0x7f0d42b6eb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16907: Jun 05, 2021 23:39:40.380 [0x7f0d42b6eb38] ERROR - [Transcode] XML: sub-chunk-00000,0.000000,3525.033000,0.000000,0.000000
	Line 16908: Jun 05, 2021 23:39:40.380 [0x7f0d42b6eb38] ERROR - [Transcode] XML: ^
	Line 16909: Jun 05, 2021 23:39:40.380 [0x7f0d42c7ab38] ERROR - Exception handled: Error parsing file
	Line 16910: Jun 05, 2021 23:39:40.380 [0x7f0d42b6eb38] ERROR - [Transcode] Error parsing content.
	Line 16911: Jun 05, 2021 23:39:40.380 [0x7f0d42b6eb38] ERROR - Exception handled: Error parsing file
	Line 16934: Jun 05, 2021 23:39:40.763 [0x7f0d4485bb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16935: Jun 05, 2021 23:39:40.763 [0x7f0d4485bb38] ERROR - [Transcode] XML: parser
	Line 16936: Jun 05, 2021 23:39:40.763 [0x7f0d4485bb38] ERROR - [Transcode] XML: error :
	Line 16937: Jun 05, 2021 23:39:40.763 [0x7f0d4485bb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16938: Jun 05, 2021 23:39:40.763 [0x7f0d4485bb38] ERROR - [Transcode] XML: sub-chunk-00000,0.000000,3525.033000,0.000000,0.000000
	Line 16939: Jun 05, 2021 23:39:40.763 [0x7f0d4485bb38] ERROR - [Transcode] XML: ^
	Line 16940: Jun 05, 2021 23:39:40.763 [0x7f0d4485bb38] ERROR - [Transcode] Error parsing content.
	Line 16941: Jun 05, 2021 23:39:40.763 [0x7f0d4485bb38] ERROR - Exception handled: Error parsing file
	Line 16942: Jun 05, 2021 23:39:40.764 [0x7f0d4129eb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16943: Jun 05, 2021 23:39:40.764 [0x7f0d4129eb38] ERROR - [Transcode] XML: parser
	Line 16944: Jun 05, 2021 23:39:40.764 [0x7f0d4129eb38] ERROR - [Transcode] XML: error :
	Line 16945: Jun 05, 2021 23:39:40.764 [0x7f0d4129eb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16946: Jun 05, 2021 23:39:40.764 [0x7f0d4129eb38] ERROR - [Transcode] XML: sub-chunk-00001,3531.825000,3533.575000,3531.825000,3531.825000
	Line 16947: Jun 05, 2021 23:39:40.764 [0x7f0d4129eb38] ERROR - [Transcode] XML: ^
	Line 16948: Jun 05, 2021 23:39:40.764 [0x7f0d4129eb38] ERROR - [Transcode] Error parsing content.
	Line 16949: Jun 05, 2021 23:39:40.764 [0x7f0d4129eb38] ERROR - Exception handled: Error parsing file
	Line 16954: Jun 05, 2021 23:39:41.107 [0x7f0d4129eb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16955: Jun 05, 2021 23:39:41.107 [0x7f0d4129eb38] ERROR - [Transcode] XML: parser
	Line 16956: Jun 05, 2021 23:39:41.107 [0x7f0d4129eb38] ERROR - [Transcode] XML: error :
	Line 16957: Jun 05, 2021 23:39:41.107 [0x7f0d4129eb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16958: Jun 05, 2021 23:39:41.107 [0x7f0d4129eb38] ERROR - [Transcode] XML: sub-chunk-00001,3531.825000,3533.575000,3531.825000,3531.825000
	Line 16959: Jun 05, 2021 23:39:41.107 [0x7f0d4129eb38] ERROR - [Transcode] XML: ^
	Line 16960: Jun 05, 2021 23:39:41.107 [0x7f0d4485bb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 16961: Jun 05, 2021 23:39:41.107 [0x7f0d4129eb38] ERROR - [Transcode] Error parsing content.
	Line 16962: Jun 05, 2021 23:39:41.107 [0x7f0d4485bb38] ERROR - [Transcode] XML: parser
	Line 16963: Jun 05, 2021 23:39:41.107 [0x7f0d4485bb38] ERROR - [Transcode] XML: error :
	Line 16964: Jun 05, 2021 23:39:41.107 [0x7f0d4485bb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 16965: Jun 05, 2021 23:39:41.107 [0x7f0d4485bb38] ERROR - [Transcode] XML: sub-chunk-00002,3534.783000,3537.408000,3534.783000,3534.783000
	Line 16966: Jun 05, 2021 23:39:41.107 [0x7f0d4485bb38] ERROR - [Transcode] XML: ^
	Line 16967: Jun 05, 2021 23:39:41.107 [0x7f0d4485bb38] ERROR - [Transcode] Error parsing content.
	Line 16968: Jun 05, 2021 23:39:41.108 [0x7f0d4129eb38] ERROR - Exception handled: Error parsing file
	Line 16969: Jun 05, 2021 23:39:41.108 [0x7f0d4485bb38] ERROR - Exception handled: Error parsing file
	Line 17072: Jun 05, 2021 23:39:41.461 [0x7f0d454ceb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 17073: Jun 05, 2021 23:39:41.461 [0x7f0d454ceb38] ERROR - [Transcode] XML: parser
	Line 17074: Jun 05, 2021 23:39:41.461 [0x7f0d454ceb38] ERROR - [Transcode] XML: error :
	Line 17075: Jun 05, 2021 23:39:41.461 [0x7f0d454ceb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 17076: Jun 05, 2021 23:39:41.461 [0x7f0d454ceb38] ERROR - [Transcode] XML: sub-chunk-00002,3534.783000,3537.408000,3534.783000,3534.783000
	Line 17077: Jun 05, 2021 23:39:41.461 [0x7f0d454ceb38] ERROR - [Transcode] XML: ^
	Line 17078: Jun 05, 2021 23:39:41.461 [0x7f0d454ceb38] ERROR - [Transcode] Error parsing content.
	Line 17079: Jun 05, 2021 23:39:41.461 [0x7f0d42c7ab38] ERROR - [Transcode] XML: Entity: line 1:
	Line 17080: Jun 05, 2021 23:39:41.461 [0x7f0d42c7ab38] ERROR - [Transcode] XML: parser
	Line 17081: Jun 05, 2021 23:39:41.461 [0x7f0d42c7ab38] ERROR - [Transcode] XML: error :
	Line 17082: Jun 05, 2021 23:39:41.461 [0x7f0d42c7ab38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 17083: Jun 05, 2021 23:39:41.461 [0x7f0d42c7ab38] ERROR - [Transcode] XML: sub-chunk-00003,3537.492000,3539.367000,3537.492000,3537.492000
	Line 17084: Jun 05, 2021 23:39:41.461 [0x7f0d42c7ab38] ERROR - [Transcode] XML: ^
	Line 17085: Jun 05, 2021 23:39:41.461 [0x7f0d42c7ab38] ERROR - [Transcode] Error parsing content.
	Line 17086: Jun 05, 2021 23:39:41.461 [0x7f0d454ceb38] ERROR - Exception handled: Error parsing file
	Line 17087: Jun 05, 2021 23:39:41.461 [0x7f0d42c7ab38] ERROR - Exception handled: Error parsing file
	Line 17210: Jun 05, 2021 23:39:41.732 [0x7f0d454ceb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 17211: Jun 05, 2021 23:39:41.732 [0x7f0d454ceb38] ERROR - [Transcode] XML: parser
	Line 17212: Jun 05, 2021 23:39:41.732 [0x7f0d454ceb38] ERROR - [Transcode] XML: error :
	Line 17213: Jun 05, 2021 23:39:41.732 [0x7f0d454ceb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 17214: Jun 05, 2021 23:39:41.732 [0x7f0d454ceb38] ERROR - [Transcode] XML: sub-chunk-00003,3537.492000,3539.367000,3537.492000,3537.492000
	Line 17215: Jun 05, 2021 23:39:41.732 [0x7f0d454ceb38] ERROR - [Transcode] XML: ^
	Line 17216: Jun 05, 2021 23:39:41.732 [0x7f0d454ceb38] ERROR - [Transcode] Error parsing content.
	Line 17217: Jun 05, 2021 23:39:41.732 [0x7f0d42c7ab38] ERROR - [Transcode] XML: Entity: line 1:
	Line 17218: Jun 05, 2021 23:39:41.732 [0x7f0d42c7ab38] ERROR - [Transcode] XML: parser
	Line 17219: Jun 05, 2021 23:39:41.732 [0x7f0d42c7ab38] ERROR - [Transcode] XML: error :
	Line 17220: Jun 05, 2021 23:39:41.732 [0x7f0d42c7ab38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 17221: Jun 05, 2021 23:39:41.732 [0x7f0d42c7ab38] ERROR - [Transcode] XML: sub-chunk-00004,3539.450000,3541.700000,3539.450000,3539.450000
	Line 17222: Jun 05, 2021 23:39:41.732 [0x7f0d42c7ab38] ERROR - [Transcode] XML: ^
	Line 17223: Jun 05, 2021 23:39:41.732 [0x7f0d454ceb38] ERROR - Exception handled: Error parsing file
	Line 17224: Jun 05, 2021 23:39:41.732 [0x7f0d42c7ab38] ERROR - [Transcode] Error parsing content.
	Line 17225: Jun 05, 2021 23:39:41.732 [0x7f0d42c7ab38] ERROR - Exception handled: Error parsing file
	Line 17238: Jun 05, 2021 23:39:42.158 [0x7f0d46680b38] DEBUG - NotificationStream: Removing because of error
	Line 17250: Jun 05, 2021 23:39:42.363 [0x7f0d42c7ab38] ERROR - [Transcode] XML: Entity: line 1:
	Line 17251: Jun 05, 2021 23:39:42.363 [0x7f0d42c7ab38] ERROR - [Transcode] XML: parser
	Line 17252: Jun 05, 2021 23:39:42.363 [0x7f0d42c7ab38] ERROR - [Transcode] XML: error :
	Line 17253: Jun 05, 2021 23:39:42.363 [0x7f0d42c7ab38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 17254: Jun 05, 2021 23:39:42.363 [0x7f0d42c7ab38] ERROR - [Transcode] XML: sub-chunk-00004,3539.450000,3541.700000,3539.450000,3539.450000
	Line 17255: Jun 05, 2021 23:39:42.363 [0x7f0d42c7ab38] ERROR - [Transcode] XML: ^
	Line 17256: Jun 05, 2021 23:39:42.363 [0x7f0d42c7ab38] ERROR - [Transcode] Error parsing content.
	Line 17257: Jun 05, 2021 23:39:42.363 [0x7f0d42b6eb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 17258: Jun 05, 2021 23:39:42.363 [0x7f0d42b6eb38] ERROR - [Transcode] XML: parser
	Line 17259: Jun 05, 2021 23:39:42.363 [0x7f0d42b6eb38] ERROR - [Transcode] XML: error :
	Line 17260: Jun 05, 2021 23:39:42.363 [0x7f0d42b6eb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 17261: Jun 05, 2021 23:39:42.363 [0x7f0d42b6eb38] ERROR - [Transcode] XML: sub-chunk-00005,3541.783000,3543.408000,3541.783000,3541.783000
	Line 17262: Jun 05, 2021 23:39:42.363 [0x7f0d42b6eb38] ERROR - [Transcode] XML: ^
	Line 17263: Jun 05, 2021 23:39:42.363 [0x7f0d42b6eb38] ERROR - [Transcode] Error parsing content.
	Line 17264: Jun 05, 2021 23:39:42.363 [0x7f0d42c7ab38] ERROR - Exception handled: Error parsing file
	Line 17265: Jun 05, 2021 23:39:42.364 [0x7f0d42b6eb38] ERROR - Exception handled: Error parsing file
	Line 17268: Jun 05, 2021 23:39:42.683 [0x7f0d4485bb38] ERROR - [Transcode] XML: Entity: line 1:
	Line 17269: Jun 05, 2021 23:39:42.683 [0x7f0d4485bb38] ERROR - [Transcode] XML: parser
	Line 17270: Jun 05, 2021 23:39:42.683 [0x7f0d4485bb38] ERROR - [Transcode] XML: error :
	Line 17271: Jun 05, 2021 23:39:42.683 [0x7f0d4485bb38] ERROR - [Transcode] XML: Start tag expected, '<' not found
	Line 17272: Jun 05, 2021 23:39:42.683 [0x7f0d4485bb38] ERROR - [Transcode] XML: sub-chunk-00005,3541.783000,3543.408000,3541.783000,3541.783000
Plex Media Server Logs_2021-06-05_23-40-27.zip (6.0 MB)
**MODERATOR EDIT: Please use CODE </> formatting for log file excerpts.
Which player are you using when this occurs?
I can’t find it in your logs.
I was using the web app, in terms of remote clients I’m not sure. This log was captured moments after the upgrade, I upgraded after I went to check on my server and was presented with a 503 error.
Thanks, that’s what I thought.
Please leave your logs there and then downgrade.
They have some problems to work out. Something got missed in testing.
I’m using 1.23.1.4528 right now which seems to be working fine. I uploaded my logs above under the excerpt.
Thank you for looking into this!
Found it.
Talking with Engineer now.
Will be fixed ASAP… they know what it is.
@kazz3r24
Please confirm – you were using sidecar (external) subtitles when this happened?
It was a remote stream, I’m trying to track it down in Tautulli now.
Yes, I do believe it was external subtitles being used.
we have that fixed already.
It will be in the next release.
The XML errors are, fortunately, noise.
The trick now is to find the deeper problem.
Find another player / anything where it works and one where it doesn’t then compare the two
I’ve got a user who just stated to me their getting playback errors in web browser as well as Plex for Windows.
Error stating Transcoder Failed - they’re trying to play it at 720p from 1080p I see nothing in the logs to indicate what the problem is.
Plex Media Server Logs_2021-06-06_15-41-45.zip (6.2 MB)
@ChuckPa I just got an alert of a playback error from a users Chrome web player. The file being played works fine when I play it using the mobile app. So I’m wondering why suddenly web browsers are having an issue playing media?
I played the same episode in my Chrome browser and it played fine with original quality but I was able to reproduce it by forcing it to transcode to a lower quality.
The error message is: Error code: s1002 (Network)
Plex Media Server Logs_2021-06-06_21-23-02.zip (6.2 MB)
I see it.
The users connection dropped on their end.
“Connection reset by peer” means the other side dropped (closed) it.
Jun 06, 2021 21:12:46.082 [0x7f5c7eff7b38] DEBUG - Content-Length of /mnt/Beta/Transcode/Sessions/plex-transcode-4tg7rfz28ateybmdrfg5h65m-42da7852-8774-4674-b1d4-0f5e564b1746/init-stream0.m4s,/mnt/Beta/Transcode/Sessions/plex-transcode-4tg7rfz28ateybmdrfg5h65m-42da7852-8774-4674-b1d4-0f5e564b1746/chunk-stream0-00617.m4s is 1720338 (of total: 1720338).
Jun 06, 2021 21:12:46.100 [0x7f5c81876b38] DEBUG - Completed: [xxx.xxx.xxx.xxx:51734] 206 GET /video/:/transcode/universal/dash/4tg7rfz28ateybmdrfg5h65m/0/616.m4s (84 live) TLS GZIP 18ms 1720338 bytes (pipelined: 3) (range: bytes=0-)
Jun 06, 2021 21:12:46.168 [0x7f5c81876b38] DEBUG - handleStreamWrite code 104: Connection reset by peer
Jun 06, 2021 21:12:46.168 [0x7f5c81876b38] DEBUG - Removed transcode data consumer, active count 6 => 5
Jun 06, 2021 21:12:46.168 [0x7f5c81876b38] DEBUG - Completed after connection close: [xxx.xxx.xxx.xxx:51691] 200 GET /video/:/transcode/universal/subtitles?Accept=application%2Fjson&Accept-Language=en&directPlay=0&directStream=0&directStreamAudio=1&protocol=dash&fastSeek=1&path=%2Flibrary%2Fmetadata%2F562294&session=4tg7rfz28ateybmdrfg5h65m&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=1280x720&audioBoost=100&subtitles=sidecar&maxVideoBitrate=4000&location=wan (84 live) TLS GZIP 879295ms 4713 bytes (pipelined: 1)
Jun 06, 2021 21:12:46.216 [0x7f5c81853b38] DEBUG - handleStreamWrite code 104: Connection reset by peer
Jun 06, 2021 21:12:46.216 [0x7f5c81853b38] DEBUG - Removed transcode data consumer, active count 5 => 4
Jun 06, 2021 21:12:46.216 [0x7f5c81853b38] DEBUG - Completed after connection close: [xxx.xxx.xxx.xxx:51696] 200 GET /video/:/transcode/universal/subtitles?Accept=application%2Fjson&Accept-Language=en&directPlay=0&directStream=0&directStreamAudio=1&protocol=dash&fastSeek=1&path=%2Flibrary%2Fmetadata%2F562294&session=4tg7rfz28ateybmdrfg5h65m&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=1280x720&audioBoost=100&subtitles=sidecar&maxVideoBitrate=4000&location=wan (84 live) TLS GZIP 843343ms 4713 bytes (pipelined: 1)
Jun 06, 2021 21:12:46.315 [0x7f5c7f3dfb38] DEBUG - [TranscodeOutputStream] Input processing thread exited after writing 4775 bytes, m_closed=1, m_endOfFileReached=1, session->isStopped()=0
Jun 06, 2021 21:12:46.315 [0x7f5c81876b38] DEBUG - handleStreamWrite code 104: Connection reset by peer
Jun 06, 2021 21:12:46.315 [0x7f5c81876b38] DEBUG - Removed transcode data consumer, active count 4 => 3
Jun 06, 2021 21:12:46.315 [0x7f5c81876b38] DEBUG - Completed after connection close: [xxx.xxx.xxx.xxx:51700] 200 GET /video/:/transcode/universal/subtitles?Accept=application%2Fjson&Accept-Language=en&directPlay=0&directStream=0&directStreamAudio=1&protocol=dash&fastSeek=1&path=%2Flibrary%2Fmetadata%2F562294&session=4tg7rfz28ateybmdrfg5h65m&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=1280x720&audioBoost=100&subtitles=sidecar&maxVideoBitrate=4000&location=wan (83 live) TLS GZIP 735455ms 4713 bytes (pipelined: 2)
Jun 06, 2021 21:12:46.317 [0x7f5c7e456b38] DEBUG - [TranscodeOutputStream] Input processing thread exited after writing 4775 bytes, m_closed=1, m_endOfFileReached=1, session->isStopped()=0
Jun 06, 2021 21:12:46.318 [0x7f5c81853b38] DEBUG - handleStreamWrite code 104: Connection reset by peer
Jun 06, 2021 21:12:46.318 [0x7f5c81853b38] DEBUG - Removed transcode data consumer, active count 3 => 2
Jun 06, 2021 21:12:46.318 [0x7f5c7e7fab38] DEBUG - [Transcode] Session 6wqc4e0s695z9bora8eyiudi (3) is unthrottling
Jun 06, 2021 21:12:46.318 [0x7f5c81853b38] DEBUG - Completed after connection close: [xxx.xxx.xxx.xxx:51698] 200 GET /video/:/transcode/universal/subtitles?Accept=application%2Fjson&Accept-Language=en&directPlay=0&directStream=0&directStreamAudio=1&protocol=dash&fastSeek=1&path=%2Flibrary%2Fmetadata%2F562294&session=4tg7rfz28ateybmdrfg5h65m&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=1280x720&audioBoost=100&subtitles=sidecar&maxVideoBitrate=4000&location=wan (82 live) TLS GZIP 771443ms 4713 bytes (pipelined: 1)
Jun 06, 2021 21:12:46.414 [0x7f5c7f4b7b38] DEBUG - [TranscodeOutputStream] Input processing thread exited after writing 4775 bytes, m_closed=1, m_endOfFileReached=1, session->isStopped()=0
Jun 06, 2021 21:12:46.414 [0x7f5c81876b38] DEBUG - handleStreamWrite code 104: Connection reset by peer
Jun 06, 2021 21:12:46.414 [0x7f5c81876b38] DEBUG - Removed transcode data consumer, active count 2 => 1
Jun 06, 2021 21:12:46.414 [0x7f5c81876b38] DEBUG - Completed after connection close: [xxx.xxx.xxx.xxx:51663] 200 GET /video/:/transcode/universal/subtitles?Accept=application%2Fjson&Accept-Language=en&directPlay=0&directStream=0&directStreamAudio=1&protocol=dash&fastSeek=1&path=%2Flibrary%2Fmetadata%2F562294&session=4tg7rfz28ateybmdrfg5h65m&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=1280x720&audioBoost=100&subtitles=sidecar&maxVideoBitrate=4000&location=wan (81 live) TLS GZIP 1002721ms 4860 bytes (pipelined: 10)
Jun 06, 2021 21:12:46.448 [0x7f5c7f94ab38] DEBUG - [TranscodeOutputStream] Input processing thread exited after writing 4775 bytes, m_closed=1, m_endOfFileReached=1, session->isStopped()=0
Jun 06, 2021 21:12:46.449 [0x7f5c81876b38] DEBUG - handleStreamWrite code 104: Connection reset by peer
Jun 06, 2021 21:12:46.449 [0x7f5c81876b38] DEBUG - Removed transcode data consumer, active count 1 => 0
Jun 06, 2021 21:12:46.449 [0x7f5c81876b38] DEBUG - Completed after connection close: [xxx.xxx.xxx.xxx:51693] 200 GET /video/:/transcode/universal/subtitles?Accept=application%2Fjson&Accept-Language=en&directPlay=0&directStream=0&directStreamAudio=1&protocol=dash&fastSeek=1&path=%2Flibrary%2Fmetadata%2F562294&session=4tg7rfz28ateybmdrfg5h65m&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=1280x720&audioBoost=100&subtitles=sidecar&maxVideoBitrate=4000&location=wan (80 live) TLS GZIP 807606ms 4713 bytes (pipelined: 3)
Jun 06, 2021 21:12:46.451 [0x7f5c804c6b38] DEBUG - [TranscodeOutputStream] Input processing thread exited after writing 4775 bytes, m_closed=1, m_endOfFileReached=1, session->isStopped()=0
Perfect, thank you for confirming that one for me! It also helps me learn how to analyze the logs.
@ChuckPa I’ve received multiple reports now from people stating they’re getting transcoding errors. At this point there must be something actually wrong. I have no choice but to roll back further, I was on 1.23.1.4528. The latest report came at 12:33am so that’s no longer in the logs.
Original quality seems to work fine, but my server at the moment will not transcode for some reason. I’ve confirmed this by attempting to transcode just a random tv episode to a lower quality and it gives an error. Definitely something wrong.
This is a log from just after I reproduce the error.
I’ve gone back to 1.22.1.4275, is there a 1.22.(2-3) version somewhere? This was the version that gave me a 503 the other day after a while. I remember the last version I had running for a good chunk of time was 1.22.2 or .3 but that’s no longer available (I need to keep an archive)…
Plex Media Server Logs_2021-06-07_07-38-01.zip (4.4 MB)
Add me to the list of people experiencing server crashes when transcoding. This was happening with server updates as recent as 1.23.2.4656. I’m attaching log files collected after the most recent crash in case they might still be needed. Rolling back to 1.22.3.4523 resolved the issue.
Linux: 4.18.19-100.fc27.x86_64
Plex Media Server Logs_2021-06-11_10-17-51.zip (1.3 MB)
What I’m seeing here looks all to be on the player side.
Jun 07, 2021 07:37:18.661 [0x7f5c759e4b38] DEBUG - [Transcode] Auth: authenticated user 1 as kazz3r24
Jun 07, 2021 07:37:18.664 [0x7f5c7db32b38] DEBUG - [Transcode/h1wpcfgejm6g2qz0xm9eclos] Returning segment 23 from session
Jun 07, 2021 07:37:18.664 [0x7f5c7db32b38] DEBUG - Content-Length of /mnt/Beta/Transcode/Sessions/plex-transcode-h1wpcfgejm6g2qz0xm9eclos-1a47adbf-79a3-4bc1-82b8-f9d70e23afce/init-stream1.m4s,/mnt/Beta/Transcode/Sessions/plex-transcode-h1wpcfgejm6g2qz0xm9eclos-1a47adbf-79a3-4bc1-82b8-f9d70e23afce/chunk-stream1-00024.m4s is 33476 (of total: 33476).
Jun 07, 2021 07:37:18.665 [0x7f5c81853b38] DEBUG - Failed to stream media, client probably disconnected after 741 bytes: 32 - Broken pipe
Jun 07, 2021 07:37:18.665 [0x7f5c81853b38] DEBUG - Completed after connection close: [192.168.0.39:63350] 200 GET /video/:/transcode/universal/dash/h1wpcfgejm6g2qz0xm9eclos/1/23.m4s (40 live) TLS GZIP 201ms 741 bytes (pipelined: 24)
This ^^ message is PMS (transcoder) trying to send the data but having the connection terminated (closed) mid-writing.
Possibilities are:
  1. Network
  2. Misbehaving client player app
Method to verify – Test for repeatability with other players
Do you have the .deb for 22.3 still? I’m only on 22.1.4275 because I can’t find my copies of the later versions, that or I deleted it thinking it was a “bad” version.
I could be wrong, but your logs don’t look complete. I’m not seeing the Plex Media Server.log files.
@SunCat
Confirming – All your “Plex Media Server” log files are missing.
what did you delete ?
I tried myself on a couple of different devices and I was getting errors when transcoding as well. I mentioned this 4 days ago when I uploaded my latest logs above.
