Conversion failed. The transcoder exited due to an error
Hi Everyone,
I have been through several forums and posts regarding my error and I still cannot seem to find a fix for this.
Been fighting this error/issue for about a month now. I unable to watch movies or tv shows without the Plex transcoder bombing out several times. Any help would be greatly appreciated!
Error: Conversion failed. The transcoder exited due to an error.
Operating System: macOS 10.15.4
Server Version#: 1.19.2.27.37
Player Version#: 4.22.3
Plex Media Server Logs_2020-05-02_01-53-45.zip (3.5 MB)
Anyone? This is still occurring, even after a full re-install, cleaning caches, etc. Here are my latest logs…Plex Media Server Logs_2020-05-26_01-03-46.zip (4.6 MB)
Uncheck the server setting for Verbose logging, recreate the problem and then download the logs. From what little I could see the network is resetting.
I unchecked “Enable Plex Media Server verbose logging” Looks like some Verbose logging still makes it in there. Here are the new logs.Plex Media Server Logs_2020-05-26_10-32-03.zip (3.7 MB)
The clearest example I could find was where you were watching a show, the buffer filled up, transcoder idled and then died when the client asked to resume. What I’m not clear about is did it fail from network or missing / corrupted file.
May 26, 2020 10:31:41.188 [0x700002544000] DEBUG - Session prbjy6ynxeimph5ebahwhw9c (4) is unthrottling
May 26, 2020 10:31:41.189 [0x7000025c7000] DEBUG - [Transcoder] Throttle - Getting back to work.
May 26, 2020 10:31:41.205 [0x7000023bb000] DEBUG - Completed: [192.168.1.251:3883] 200 GET /video/:/transcode/universal/dash/prbjy6ynxeimph5ebahwhw9c/0/37.m4s (14 live) TLS GZIP 83ms 2974798 bytes (pipelined: 2)
May 26, 2020 10:31:42.003 [0x700002338000] DEBUG - Auth: authenticated user 1 as xiantez
May 26, 2020 10:31:42.003 [0x70000295c000] DEBUG - Request: [192.168.1.251:3883 (Subnet)] GET /:/timeline?ratingKey=11416&key=%2Flibrary%2Fmetadata%2F11416&playbackTime=176712&playQueueItemID=316&state=playing&hasMDE=1&time=116000&duration=2508000 (14 live) TLS GZIP Signed-in Token (xiantez)
May 26, 2020 10:31:42.003 [0x70000295c000] DEBUG - Client [yyto2chdnzelqaa92tag47cc] reporting timeline state playing, progress of 116000/2508000ms for guid=, playbackTime=176712ms ratingKey=11416 url=, key=/library/metadata/11416, containerKey=, metadataId=11416, source=
May 26, 2020 10:31:42.004 [0x70000295c000] DEBUG - Play progress on 11416 'Nyle Hatcher' - got played 116000 ms by account 1!
May 26, 2020 10:31:42.005 [0x70000295c000] DEBUG - [Now] User is xiantez (ID: 1)
May 26, 2020 10:31:42.005 [0x70000295c000] DEBUG - [Now] Device is Chrome (Chrome).
May 26, 2020 10:31:42.005 [0x70000295c000] DEBUG - [Now] Profile is Web
May 26, 2020 10:31:42.005 [0x70000295c000] DEBUG - [Now] Updated play state for /library/metadata/11416.
May 26, 2020 10:31:42.005 [0x70000295c000] DEBUG - Statistics: (9h41x9wmb7li5n2phk7lxwqj) Reporting active playback in state 0 of type 4 (scrobble: 0) for account 1
May 26, 2020 10:31:42.008 [0x700002338000] DEBUG - Completed: [192.168.1.251:3883] 200 GET /:/timeline?ratingKey=11416&key=%2Flibrary%2Fmetadata%2F11416&playbackTime=176712&playQueueItemID=316&state=playing&hasMDE=1&time=116000&duration=2508000 (14 live) TLS GZIP 5ms 848 bytes (pipelined: 3)
May 26, 2020 10:31:46.298 [0x70000295c000] ERROR - [Transcoder] [tcp @ 0x7f9107d0d0c0] Connection to tcp://127.0.0.1:32400 failed: Operation timed out
May 26, 2020 10:31:46.299 [0x700002d74000] ERROR - [Transcoder] [dash @ 0x7f9108838000] Unable to open http://127.0.0.1:32400/video/:/transcode/session/prbjy6ynxeimph5ebahwhw9c/4e8a0f4d-6d59-4df2-b23a-d47883337f47/manifest?X-Plex-Http-Pipeline=infinite for writing: Operation timed out
May 26, 2020 10:31:46.300 [0x70000243e000] ERROR - [Transcoder] av_interleaved_write_frame(): Operation timed out
May 26, 2020 10:31:47.116 [0x700002b68000] DEBUG - Transcoder segment range: 0 - 49 (49)
May 26, 2020 10:31:47.122 [0x700002232000] DEBUG - Jobs: '/Applications/Plex Media Server.app/Contents/MacOS/Plex Transcoder' exit code for process 14466 is 1 (failure)
There is a Plex for Max/Windows client that would be able to direct play the file instead of the browser if this is only client having issues.
You do seem to have a network configuration issues, en0 can’t find the default gateway and when it does it the it gets different addresses( 192.x to 10.x back to 192.x). Another adapter en1 was added and then dropped, was this intentional?
Thanks for looking into it. At this point I’m at a loss. Here’s what I’ve done thus far to troubleshoot.
  1. Disable all VPNs
  2. Completely uninstall PMS. Cleared all leftover files, caches, etc.
  3. Scanned both external drives for errors and corrupted sectors.
  4. Rebooted the mac mini (multiple times).
  5. Updated macOS to latest Catalina OS version.
  6. Swapped out USB cables to my external hard drives
  7. Swapped out Ethernet cable from my router to my PMS (mac mini)
I’ll keep poking around. Appreciate your help.
