hallo everybody
i have plex on my desk to have all my movies in drive and watching on my samsung tv before 3 days some movies made me do that Conversion failed. The transcoder exited due to an error
has it happened to anyone else?
A mí me ocurre lo mismo en un televisor LG.
Cada cierto tiempo se para la reproducción y aparece el mensaje de error del transcoder. Parados unos segundos, le doy a reproducir y continúa hasta el próximo error.
Tú estarás en América, yo estoy en España. Hablaré como quiera, no te parece?
Aquí se trata de buscar soluciones, no hacer el pamplinas como lo estás haciendo tú
I uninstalled the current version of plex as follows:
Stop Plex from the icon in the taskbar.
Uninstall Plex from the Control Panel. Do not use any external tool, nor use tools that can modify the Windows registry in any way.
Install the previous version, which is the one you were using without problems. In the Plex TEMP folder " \ Plex Media Server \ Updates" you have all the versions that you have been updating.
Normally install the version that worked for you. No need to reboot.
With this I have kept all the Plex configuration without having to do anything
I changed my scanning to once per day. Since doing that, I have not had any of the transcode errors. I may just leave it that way for now. But if the errors return before Plex fixes this, I will then downgrade.
i bay apple tv and i run plex … end dont have problems now ! but in app plex for samsung or in my pc the erros transcoding is everyware ! maybe is the player
