PLEASE HELP! Transcoder error, nothing plays, or help downgrading?
Server Version#: 4.87.2
Plex Media Server Logs_2022-12-16_20-28-21.zip (3.0 MB)
Started getting the error “Playback Error - Conversion failed. The transcoder failed to start up.” when trying to play on my computer (Windows 11 Pro, v 22H2, OS Build 22621.963) where my Plex is installed. Others unable to watch on remote devices. Happens with new and older video files that have played fine before, and that I can play just fine on the computer with VLC Media Player. Everything seemed fine until a week or so ago when it all started. Doesn’t happen with every file, but seems to be getting worse. Logs are attached.
Could this be from a recent update? Timing is close.
If due to the update, how can I downgrade to an older version of Plex without having to rebuild my libraries again?
Where can I find an older version to install?
Looking for any advice on how to fix this so my family and I can watch again.
Thank you.
Looks like you have Plex installed in a custom directory and the program is unable to find/access the transcoder executable.
Does this file exist?
D:\Programs\Plex\Plex Transcoder.exe
No, it doesn’t. I’ve always installed Plex on a different drive than C:. I don’t understand how it could’ve been working just fine for the last 10+ months since I installed (new build) and suddenly it doesn’t. Very strange.
Can I just uninstall and reinstall to fix it? And if so, will I have to rebuild/reset all my libraries?
Thanks for any help you can suggest.
That should work. You could also try a repair. Just re-run the installer for the same version you have now. Double check this file exists afterwards.
Much thanks!!! Reinstalling it fixed it without any issues. Still don’t understand how the transcoder file disappeared. Also noticed when I reinstalled that I was running the 32 bit version, not the 64 bit, so fixed that as well. All libraries intact and everything back to normal now. Again, MUCH, MUCH THANKS!!!
