Server Version#: 1.21.2.3939
Player Version#:4.51.1
Hi. After a Server reboot, All I get is Conversion failed. The transcoder exited due to an error.
In this log I tried it with Moana, but I have it with everything I try to play.
Anyone an idea?Plex Media Server Logs_2021-01-27_18-07-00.zip (2.6 MB)
The server is having a problem with this source path.
Jan 27, 2021 18:04:34.047 [0x7fa8f1ffb700] DEBUG - [Transcode] Found session GUID of q7txm5xw53mg7qffoven7eor in session start.
Jan 27, 2021 18:04:34.047 [0x7fa8f1ffb700] DEBUG - [Transcode] Cleaning directory for session q7txm5xw53mg7qffoven7eor ()
Jan 27, 2021 18:04:34.047 [0x7fa8f1ffb700] DEBUG - [Transcode] Starting a transcode session q7txm5xw53mg7qffoven7eor at offset -1.0 (state=3)
Jan 27, 2021 18:04:34.048 [0x7fa8f1ffb700] DEBUG - [Transcode] [Universal] Using local file path instead of URL: /mnt/unionfs/movies/HD/Moana (2016)/Moana (2016) Remux-1080p.mkv
Jan 27, 2021 18:04:34.048 [0x7fa8f1ffb700] DEBUG - [Transcode] Job running: FFMPEG_EXTERNAL_LIBS='/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Codecs/367b3d4-3673-linux-x86_64/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxs' '/usr/lib/plexmediaserver/Plex Transcoder' '-codec:0' 'h264' '-codec:2' 'dca' '-ss' '0' '-noaccurate_seek' '-analyzeduration' '20000000' '-probesize' '20000000' '-i' '/mnt/unionfs/movies/HD/Moana (2016)/Moana (2016) Remux-1080p.mkv' '-map' '0:0' '-metadata:s:0' 'language=eng' '-codec:0' 'copy' '-filter_complex' '[0:2] aresample=async=1:ocl='\''stereo'\'':rematrix_maxval=0.000000dB:osr=48000[0]' '-map' '[0]' '-metadata:s:1' 'language=eng' '-codec:1' 'aac' '-b:1' '256k' '-f' 'dash' '-seg_duration' '5' '-init_seg_name' 'init-stream$RepresentationID$.m4s' '-media_seg_name' 'chunk-stream$RepresentationID$-$Number%05d$.m4s' '-window_size' '5' '-delete_removed' 'false' '-skip_to_segment' '1' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/q7txm5xw53mg7qffoven7eor/2166f930-6648-44f1-b63e-11c03c9ed14a/manifest?X-Plex-Http-Pipeline=infinite' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'dash' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/q7txm5xw53mg7qffoven7eor/2166f930-6648-44f1-b63e-11c03c9ed14a/progress'
Jan 27, 2021 18:04:34.049 [0x7fa8f1ffb700] DEBUG - [Transcode] Jobs: Starting child process with pid 32763
Jan 27, 2021 18:04:34.055 [0x7fa8e9ffb700] DEBUG - Request: [127.0.0.1:36532 (Loopback)] PUT /video/:/transcode/session/q7txm5xw53mg7qffoven7eor/2166f930-6648-44f1-b63e-11c03c9ed14a/progress?status=startup (18 live) Signed-in Token (MadDemonoide) (range: bytes=0-)
Jan 27, 2021 18:04:34.055 [0x7fa95624f700] DEBUG - Completed: [127.0.0.1:36532] 204 PUT /video/:/transcode/session/q7txm5xw53mg7qffoven7eor/2166f930-6648-44f1-b63e-11c03c9ed14a/progress?status=startup (18 live) 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Jan 27, 2021 18:04:34.058 [0x7fa8f0ff9700] DEBUG - Request: [127.0.0.1:36532 (Loopback)] PUT /video/:/transcode/session/q7txm5xw53mg7qffoven7eor/2166f930-6648-44f1-b63e-11c03c9ed14a/progress?status=startup (18 live) Signed-in Token (MadDemonoide) (range: bytes=0-)
Jan 27, 2021 18:04:34.058 [0x7fa955a4e700] DEBUG - Completed: [127.0.0.1:36532] 204 PUT /video/:/transcode/session/q7txm5xw53mg7qffoven7eor/2166f930-6648-44f1-b63e-11c03c9ed14a/progress?status=startup (18 live) 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Jan 27, 2021 18:04:34.058 [0x7fa8e97fa700] DEBUG - Request: [127.0.0.1:36532 (Loopback)] PUT /video/:/transcode/session/q7txm5xw53mg7qffoven7eor/2166f930-6648-44f1-b63e-11c03c9ed14a/progress?status=opening (18 live) Signed-in Token (MadDemonoide) (range: bytes=0-)
Jan 27, 2021 18:04:34.058 [0x7fa95624f700] DEBUG - Completed: [127.0.0.1:36532] 204 PUT /video/:/transcode/session/q7txm5xw53mg7qffoven7eor/2166f930-6648-44f1-b63e-11c03c9ed14a/progress?status=opening (18 live) 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Jan 27, 2021 18:04:34.689 [0x7fa8f17fa700] ERROR - [Transcoder] /mnt/unionfs/movies/HD/Moana (2016)/Moana (2016) Remux-1080p.mkv: Input/output error
Jan 27, 2021 18:04:34.691 [0x7fa95e7b5700] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 32763 is 1 (failure)
Jan 27, 2021 18:04:34.691 [0x7fa8f1ffb700] DEBUG - [Transcode] Using default transcode duration of 120 minutes
Jan 27, 2021 18:04:34.691 [0x7fa92bfff700] DEBUG - Streaming Resource: Terminating session 0x7fa8e414e460:u34u48zprrgcxu85idw91pxs which is using 57862kbps of WAN bandwidth. Used is now 0kbps
Jan 27, 2021 18:04:34.691 [0x7fa92bfff700] DEBUG - Streaming Resource: Terminated session 0x7fa8e414e460:u34u48zprrgcxu85idw91pxs with reason Conversion failed. The transcoder exited due to an error.
Jan 27, 2021 18:04:34.691 [0x7fa8f1ffb700] DEBUG - [Transcode] Started session successfully: q7txm5xw53mg7qffoven7eor
Jan 27, 2021 18:04:34.692 [0x7fa92a7fc700] DEBUG - Killing job.
Jan 27, 2021 18:04:34.692 [0x7fa92a7fc700] DEBUG - Signalling job ID 32763 with 9
Jan 27, 2021 18:04:34.692 [0x7fa92a7fc700] DEBUG - Job was already killed, not killing again.
Jan 27, 2021 18:04:34.692 [0x7fa92a7fc700] DEBUG - Stopping transcode session q7txm5xw53mg7qffoven7eor
Jan 27, 2021 18:04:34.692 [0x7fa95624f700] DEBUG - handleStreamWrite code 32: Broken pipe
Jan 27, 2021 18:04:34.692 [0x7fa95624f700] DEBUG - NotificationStream: Removing because of error
Jan 27, 2021 18:04:34.692 [0x7fa955a4e700] DEBUG - handleStreamWrite code 32: Broken pipe
Jan 27, 2021 18:04:34.692 [0x7fa955a4e700] DEBUG - NotificationStream: Removing because of error
Did your machine install updates recently?
Yes, I actually updated Plex and Ubuntu, this happened short after.
I suspect Ubuntu. It looks a lot like a file system error with UnionFS. “input/output” error is a fairly “smoking gun” in this case.
Cam you check by manually launching a FFMPEG session to a dummy output file?
Somehow it started working out of itself again. No clue what it really was.
