Convert automatically broken?
Server Version#: 1.25.2.5319
Player Version#: All clients
Convert automatically seems broken, it used to work fine, but now won’t play to any client when accessing remotely! I have to turn off Convert Automatically in settings and mess with quality settings to get anything to play! This is from multiple locations. I’ve hopefully attached logs. Thanks, Tim
Plex Media Server Logs_2021-12-19_17-44-16.zip (5.3 MB)
@Mothy_Tim
I see your logs and a transcode session starting, Thank you for posting :slight_smile:
Here, I can see it looking for the Hardware but not finding it.
Did you forget to passthrough in the container definition ?
Dec 19, 2021 16:47:02.686 [0x145f7257cb38] DEBUG - [Transcode] It took 10.000000 ms to retrieve 120 items.
Dec 19, 2021 16:47:02.694 [0x145f7257cb38] DEBUG - [Transcode] It took 0.000000 ms to retrieve 120 items.
Dec 19, 2021 16:47:02.696 [0x145f7257cb38] DEBUG - [Transcode] We're going to try to auto-select an audio stream for account 1.
Dec 19, 2021 16:47:02.696 [0x145f7257cb38] DEBUG - [Transcode] Selecting best audio stream for part ID 54427 (autoselect: 1 language: en)
Dec 19, 2021 16:47:02.696 [0x145f7257cb38] DEBUG - [Transcode] We're going to try to auto-select a subtitle.
Dec 19, 2021 16:47:02.696 [0x145f7257cb38] DEBUG - [Transcode] Audio Stream: 117182, Subtitle Stream: -1
Dec 19, 2021 16:47:02.699 [0x145f7257cb38] DEBUG - [Transcode] MDE: Selected protocol hls; container: mkv
Dec 19, 2021 16:47:02.699 [0x145f7257cb38] DEBUG - [Transcode] MDE: analyzing media item 52487
Dec 19, 2021 16:47:02.699 [0x145f7257cb38] DEBUG - [Transcode] MDE: Gremlins 2: The New Batch (1990): Direct Play is disabled
Dec 19, 2021 16:47:02.699 [0x145f7257cb38] DEBUG - [Transcode] MDE: Gremlins 2: The New Batch (1990): media must be transcoded in order to use the hls protocol
Dec 19, 2021 16:47:02.699 [0x145f7257cb38] DEBUG - [Transcode] MDE: Gremlins 2: The New Batch (1990): no direct play video profile exists for http/mkv/h264
Dec 19, 2021 16:47:02.699 [0x145f7257cb38] DEBUG - [Transcode] MDE: Gremlins 2: The New Batch (1990): no direct play video profile exists for http/mkv/h264/dca
Dec 19, 2021 16:47:02.701 [0x145f7257cb38] DEBUG - [Transcode] MDE: Gremlins 2: The New Batch (1990): selected media 0 / 52487
Dec 19, 2021 16:47:02.701 [0x145f7257cb38] DEBUG - [Transcode] Streaming Resource: Reached Decision id=48447 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=52487 part=(id=54427 decision=transcode container=mkv protocol=hls streams=(Video=(id=117181 decision=copy width=1920 height=1080) Audio=(id=117182 decision=copy channels=6 rate=48000))))
Dec 19, 2021 16:47:02.703 [0x145f74c14b38] DEBUG - Completed: [10.19.64.64:44350] 200 GET /video/:/transcode/universal/decision?audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F48447&protocol=*&session=46faa299c3fb39c8-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160 (12 live) TLS GZIP 44ms 3809 bytes (pipelined: 8)
Dec 19, 2021 16:47:03.024 [0x145f6f9b4b38] DEBUG - Request: [10.19.64.64:44398 (Subnet)] GET /video/:/transcode/universal/start.m3u8?audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F48447&protocol=hls&session=46faa299c3fb39c8-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160 (13 live) TLS Signed-in Token (Mothy_Tim) (range: bytes=0-)
Dec 19, 2021 16:47:03.024 [0x145f6f9b4b38] DEBUG - [Transcode] Found session GUID of 46faa299c3fb39c8-com-plexapp-android in session start.
Dec 19, 2021 16:47:03.026 [0x145f6f9b4b38] DEBUG - [Transcode] TranscodeUniversalRequest: using augmented profile Android
Dec 19, 2021 16:47:03.026 [0x145f6f9b4b38] DEBUG - [Transcode] Downloading document http://127.0.0.1:32400/library/metadata/48447?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=46faa299c3fb39c8-com-plexapp-android
Dec 19, 2021 16:47:03.028 [0x145f6f9b4b38] DEBUG - [Transcode] It took 0.000000 ms to retrieve 120 items.
Dec 19, 2021 16:47:03.031 [0x145f6f9b4b38] DEBUG - [Transcode] It took 0.000000 ms to retrieve 120 items.
Dec 19, 2021 16:47:03.082 [0x145f6f9b4b38] DEBUG - [Transcode] We're going to try to auto-select an audio stream for account 1.
Dec 19, 2021 16:47:03.082 [0x145f6f9b4b38] DEBUG - [Transcode] Selecting best audio stream for part ID 54427 (autoselect: 1 language: en)
Dec 19, 2021 16:47:03.082 [0x145f6f9b4b38] DEBUG - [Transcode] We're going to try to auto-select a subtitle.
Dec 19, 2021 16:47:03.082 [0x145f6f9b4b38] DEBUG - [Transcode] Audio Stream: 117182, Subtitle Stream: -1
Dec 19, 2021 16:47:03.083 [0x145f6f9b4b38] DEBUG - [Transcode] Found session GUID of 46faa299c3fb39c8-com-plexapp-android in session start.
Dec 19, 2021 16:47:03.083 [0x145f6f9b4b38] DEBUG - [Transcode] Using session GUID 46faa299c3fb39c8-com-plexapp-android for new transcode session.
Dec 19, 2021 16:47:03.083 [0x145f6f9b4b38] DEBUG - [Transcode] Cleaning directory for session 46faa299c3fb39c8-com-plexapp-android ()
Dec 19, 2021 16:47:03.084 [0x145f74c14b38] DEBUG - Completed: [10.19.64.64:44398] 206 GET /video/:/transcode/universal/start.m3u8?audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F48447&protocol=hls&session=46faa299c3fb39c8-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160 (13 live) TLS 59ms 394 bytes (range: bytes=0-)
Dec 19, 2021 16:47:03.194 [0x145f7257cb38] DEBUG - Request: [10.19.64.64:44400 (Subnet)] GET /video/:/transcode/universal/session/46faa299c3fb39c8-com-plexapp-android/base/index.m3u8 (14 live) TLS Signed-in
Dec 19, 2021 16:47:03.194 [0x145f7257cb38] DEBUG - [Transcode/46faa299c3fb39c8-com-plexapp-android] Starting a transcode session 46faa299c3fb39c8-com-plexapp-android at offset -1.0 (state=3)
Dec 19, 2021 16:47:03.195 [0x145f7257cb38] DEBUG - [Transcode/46faa299c3fb39c8-com-plexapp-android] TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Dec 19, 2021 16:47:03.195 [0x145f7257cb38] DEBUG - [Transcode/46faa299c3fb39c8-com-plexapp-android] [Universal] Using local file path instead of URL: /data/Movies/Gremlins 2 The New Batch (1990)/Gremlins.2.The.New.Batch.1990.Unknown.mkv
Dec 19, 2021 16:47:03.195 [0x145f7257cb38] DEBUG - [Transcode/46faa299c3fb39c8-com-plexapp-android] TPU: hardware transcoding: final decoder: , final encoder:
Dec 19, 2021 16:47:03.195 [0x145f7257cb38] DEBUG - [Transcode/46faa299c3fb39c8-com-plexapp-android/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/fb9eae3-4185-linux-x86_64/' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/usr/lib/plexmediaserver/Plex Transcoder' '-codec:0' 'h264' '-noaccurate_seek' '-analyzeduration' '20000000' '-probesize' '20000000' '-i' '/data/Movies/Gremlins 2 The New Batch (1990)/Gremlins.2.The.New.Batch.1990.Unknown.mkv' '-map' '0:0' '-metadata:s:0' 'language=eng' '-codec:0' 'copy' '-map' '0:1' '-metadata:s:1' 'language=eng' '-codec:1' 'copy' '-segment_format' 'matroska' '-f' 'ssegment' '-individual_header_trailer' '0' '-flags' '+global_header' '-segment_header_filename' 'header' '-segment_time' '10' '-segment_start_number' '0' '-segment_copyts' '1' '-segment_time_delta' '0.0625' '-segment_list' 'http://127.0.0.1:32400/video/:/transcode/session/46faa299c3fb39c8-com-plexapp-android/5f833f3a-996a-45cb-a9a0-4f043cf2145c/manifest?X-Plex-Http-Pipeline=infinite' '-segment_list_type' 'csv' '-segment_list_size' '5' '-segment_list_separate_stream_times' '1' '-segment_list_unfinished' '1' '-segment_format_options' 'output_ts_offset=10' '-max_delay' '5000000' '-avoid_negative_ts' 'disabled' '-map_metadata:g' '-1' '-map_metadata:c' '-1' '-map_chapters' '-1' 'media-%05d.ts' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/46faa299c3fb39c8-com-plexapp-android/5f833f3a-996a-45cb-a9a0-4f043cf2145c/progress'
Dec 19, 2021 16:47:03.196 [0x145f7257cb38] DEBUG - [Transcode/46faa299c3fb39c8-com-plexapp-android/JobRunner] Jobs: Starting child process with pid 840
Hi, thanks for the speedy reply.
Ok weird I was watching Gremlins 2 here and it was playing fine! Didn’t notice that it was transcoding, it normally direct plays at home! Yes the GPU passthrough is set up, it has always worked since I set it up on UnRaid a few years ago, there is normally an HW showing in Tautulli when transcoding? My daughter was trying to watch a film last night on her Apple TV at around 10:30 that failed to play without switching off convert automatically?
Tim
@Mothy_Tim
If I may ask again, Are you aware the Intel QSV ASIC (UHD 630) isn’t being passed through to the container?
 --device=/dev/dri:/dev/dri
Would you recreate a specific failure such that it’s the last thing in the logs ?
Yes, I have that line in my container config and it shows high activity in the GPU dashboard so I thought it was working? I’ll get my daughter to play something and post the logs.
Cheers,
Tim
Hi @ChuckPa
Sorry for the delay, I’ve had to wait for someone to be at my parents house to try and play something! Attached is the log.
Cheers,
Tim
Plex Media Server Logs_2021-12-22_15-55-07.zip (6.3 MB)
Hi @ChuckPa
I’ve discovered today that I have this problem on my older FireTV Stick (Gen 2 I think) (that is in the back bedroom for when one of the kids comes home to stay, so I don’t use it often!) I fact this seems to be a problem that mostly affects the Fire TV sticks, my daughter’s Apple TV is fine! So anyway I played a 4K Bluray rip that I knew would have to transcode a few times and if I had “convert automatically” set then it wouldn’t play, just had the spinning icon! It did this whatever quality I selected! Logs attached.
Thanks, and Happy Christmas!
Tim
Plex Media Server Logs_2021-12-24_12-56-19.zip (4.5 MB)
It’s been 2 weeks now! As usual no answer from Plex!! Don’t know why I expected any different! Worst support from one of the most bug ridden bits of software I have to use, as annoyingly there is no alternative!!
@Mothy_Tim
I’m sorry for the delay but there was a holiday and end of year vacations. I tried to take some much needed time off.
In reviewing your logs, I looked for AppleTV and FireStick. I didn’t find either attempting to play.
Can you help me out?
If it helps i have had the same issue with plex web in chrome for the last couple months with the same issue regardless of the media on a shield 2019 pro.
It never goes to Auto anymore and stays at Converting Automatically
I just did one now from 11:55-11:57AM as a test and here are the logs. It’s been broken for about 3 months or so but I figured it might just come back after a couple updates but no luck. Internally it works it seems to be mainly Plex Web that is the issue in my case.
It seems to work on the mobile android and shield android app okay.
Plex Media Server Logs_2022-01-10_11-57-27.zip (2.1 MB)
Hi, No worries, I hope you had a good break!
You’ll find the Firestick on 24th Dec at 12:40 ish it’s named AFTT-BackBedroom, I was playing Star Wars Ep1. The Apple TV on the 22nd Dec at 10:57 playing Polar Express.
Thanks,
Tim
@Mothy_Tim
  1. ASS subtitles and Player settings / limitations of device
Dec 24, 2021 12:35:38.207 [0x149696b46b38] DEBUG - [Transcode] MDE: Star Wars: Episode I - The Phantom Menace (1999): Audio Direct Streaming is disabled, so video's audio stream will be transcoded
Dec 24, 2021 12:35:38.211 [0x149696b46b38] DEBUG - [Transcode] MDE: Cannot direct stream audio stream due to profile or setting limitations
Dec 24, 2021 12:35:38.212 [0x149696b46b38] DEBUG - [Transcode] MDE: Star Wars: Episode I - The Phantom Menace (1999): selected media 0 / 77496
Dec 24, 2021 12:35:38.212 [0x149696b46b38] DEBUG - [Transcode] Streaming Resource: Reached Decision id=62459 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=77496 part=(id=79437 decision=transcode container=mkv protocol=hls streams=(Video=(id=209036 decision=transcode bitrate=7246 encoder=h264_vaapi width=1920 height=1080) Audio=(id=209038 decision=transcode bitrate=321 encoder=libopus channels=6 rate=48000) Subtitle=(id=209276 decision=transcode bitrate=2147483647 encoder=ass languageCode=eng location=embedded))))
Dec 24, 2021 12:35:38.214 [0x149698661b38] DEBUG - Completed: [10.19.64.45:59821] 200 GET /video/:/transcode/universal/decision?advancedSubtitles=text&audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=8000&mediaBufferSize=104832&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F62459&protocol=*&session=d64330bce773dacd-com-plexapp-android&subtitles=embedded&subtitleSize=100&videoBitrate=8000&videoQuality=60&videoResolution=1920x1080 (11 live) TLS GZIP 59ms 6185 bytes (pipelined: 11)
Dec 24, 2021 12:35:39.022 [0x149696b46b38] DEBUG - Request: [172.19.0.14:57100 (WAN)] GET /status/sessions (13 live) GZIP Signed-in Token (Mothy_Tim)
Dec 24, 2021 12:35:39.022 [0x149696b46b38] DEBUG - [Now] Adding 0 sessions.
  1. December 22nd not in the logs.
This is Plex Media Server.5.log
Dec 23, 2021 18:39:04.270 [0x1542764e2b38] INFO - Plex Media Server v1.25.2.5319-c43dc0277 - Docker Docker Container x86_64 - build: linux-x86_64 debian - GMT 00:00
Dec 23, 2021 18:39:04.270 [0x1542764e2b38] INFO - Linux version: 5.14.15-Unraid, language: en-US
Dec 23, 2021 18:39:04.270 [0x1542764e2b38] INFO - Processor Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
Dec 23, 2021 18:39:04.270 [0x1542764e2b38] INFO - Compiler is - Clang 11.0.1 (https://plex.tv b587490162c22e078c314e3f7dc560c691d126aa)
Dec 23, 2021 18:39:04.270 [0x1542764e2b38] INFO - /usr/lib/plexmediaserver/Plex Media Server
Dec 23, 2021 18:39:04.262 [0x15426f38bb38] ERROR - Subscription: Error refreshing sub: No container found
Dec 23, 2021 18:39:04.263 [0x15426f38bb38] DEBUG - Activity: updated activity 1998c705-57e1-4b44-9399-7599f627f515 - completed 0.0% - Refreshing Sub
Dec 23, 2021 18:39:04.263 [0x15426f38bb38] DEBUG - Activity: Ended activity 1998c705-57e1-4b44-9399-7599f627f515.
Dec 23, 2021 18:39:04.264 [0x15426f22fb38] ERROR - downloadContainer: expected MediaContainer element, found html
Dec 23, 2021 18:39:04.264 [0x15426f22fb38] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:2/metadata/plex%3A%2F%2Fshow%2F6093f8dc78a234002c83a905
Dec 23, 2021 18:39:04.264 [0x15426f22fb38] ERROR - Subscription: Error refreshing sub: No container found
Dec 23, 2021 18:39:04.264 [0x15426f22fb38] DEBUG - Activity: updated activity d114ee25-f406-4745-a2d6-03d08061f8b1 - completed 0.0% - Re
The Polar Express is scanned when the scanner runs but nothing new reported about it (nothing changed)
