Cordcutter TV ATSC (46451) 46451 Tuner No Channels Found . H&I
I an trying to add a
It scans channels finds 50 then says no Channels Found.
suspect from searching that 2.4 H&I may be the culprit.
Plex Media Server Logs_2019-04-06_11-19-14.zip (3.3 MB)
I may have missed it but I don’t see this tuner in the list of officially supported tuners.
https://support.plex.tv/articles/225877427-supported-dvr-tuners-and-antennas/
Okay, this Hauppauge Support | Cordcutter TV says Plex will support it. Do you have the latest firmware installed on the tuner?
I have the latest Firmware. It has Something to do with the & in H&I channel breaking the database. It needs a plex fix from what I can tell. Its picked up in the first 6 channels
so I cant even stop the scan to get a partial channel list
Ah yes, sorry for missing what you meant about H&I as a channel.
Yes, a bug report has been filed for this issue.
Thank you for following up
