Core component error
Appreciate the information here! We are still working on it and this helps!
I was just doing a clean install on linux and had this issue. I switched to a windows install and the issue persists. It is happens on localhost, specific ip and app.plex.tv all the same. Once clicked through the server seems working fine, but it does appear every time.
Me too- first timer here with new install on MacBook Air/Monterey
Sorry cannot find log files anywhere!
Today I installed Proxmox 9 and I’m also getting this error. At first, I thought it was a Promox issue, but it doesn’t work on Ubuntu either. I’m here to check on the forum to see that many people are having problems with the new version of PLEX.
see the linked support article – you can either download the server logs from the server settings in the web app, or find them in your local file system.
Plex Media Server Logs_2025-08-09_22-48-39.zip (361.7 KB)
ran into the same issue, tried to reinstall on unRAID server, still doesn’t work… relegated to reading this evening. Here are my logs.
I have been scratching my head for an hour before finding this thread, so let me add my experience:
  • I am running Proxmox VE 8.4 with kernel 6.11.11-2-pve (opt-in) on an x86-64 AMD server
  • I am installing Plex in a container based on their (Proxmox provided) debian-12-standard_12.7-1_amd64.tar.zst template.
  • I am creating an unprivileged container with nesting support enabled (to make systemd namespaces happy).
  • I am installing plexmediaserver_1.42.1.10054-f333bdaa8_amd64.deb (sha1:8969768c34b365d7eb481101ada401cbd9627e79)
  • This is a new install, and I have reproduced it multiple times on fresh containers
    • Another server I run, running PVE 8.3 with kernel 6.8 (on an Intel x86-64 platform), in a Debian 12 LXC container configured the same way, was able to be upgraded to 1.42.1.10054 (via the apt/deb repo) and is not giving me this problem so far
Edit: To clarify my experience with the bug:
  • During initial setup, I get the core component error message
  • I can skip past it by clicking the 1st tab of the setup, and I can finish setup even, add libraries, stream media, etc
  • Every time I go to the web UI (/web/index.html), however, I am met with the setup page again
    • I still get the core component error
    • And I can still click into the tabs and get past it
However, clearly there is some internal state that is messed up…
IMO this installer should be pulled until it’s fixed
Thanks for providing that link Keir- I can confirm dropping plexmediaserver_1.41.9.9961-46083195d_amd64.deb into my Ansible playbook solved my issue and the server installed without getting stuck.
(I will not be upgrading via apt until a fix is released, however, because I have sunk enough time into this tonight.)
Server Version#: v.1.42.1.10054-f333bdaa8
Player Version#: 1.42.1.10054
With a fresh Debian 13 install, I have an issue where Plex falls back to the setup wizard screen with an error “A problem has been detected with a core component of Plex Media Server”
The server works if I press finish-done, but upon refreshing the web page, it falls back to the same setup wizard with this error. I have attached the logs.
Plex Media Server Logs_2025-08-10_11-20-26.zip (46.4 KB)
MOD EDIT: Moved your post to this thread, as it is the same issue. @FordGuy61
@ChuckPa - Anything for Windows x64 by any chance? I’m facing the exact same issues with Windows 11 IoT LTSC, thanks.
ALL:
This is top priority for Engineering.
As soon as they have a working resolution which is stable,
I will post here and provide upgrade links.
For you redhat/fedora people, here is their previous version link for “Fedora (27+) / CentOS (7+) / SUSE (15+) - Intel/AMD 64-bit” :
Edit: NVM, support says not to use this version (1.41.9.9961-46083195d) although it’s working fine for me
I have the steps to get over the Core Component Error.
It’s a hiccup in Plex/web talking to PMS as it starts.
Specifically, it faults when PMS launches the Setup Wizard.
You can get around it by invoking the Setup Wizard manually.
  1. install PMS
  2. Open it in the web browser
  3. Sign in
  4. Get the “Got it”
  5. At this point, you will see the error
Invoke the Setup Wizard
  1. Click “Name”
  2. Now proceed normally through the Setup Wizard
That doesn’t solve the issue. If you reload the page it’s back at the server setup window.
Could you provide links for the previous version?
I have the exact same problem I just installed debian 13 it fails with same error. i have installed it many time on many different versions of linux no issues even Ubuntu 25.10 snapshot 3 worked like a charm.. This time I tried in on M4 macMini just to see it was just debian 13 but no it happens on Tahoe 26 beta as well hope this helps
PLEASE DISREGARD I just re-read and clicking on name seems to have worked.
Apologies
Plex Media Server Downgrade – Ubuntu LXC container under Proxmox
Verify Current Installation
Check your current Plex version and status:
# Check service status
sudo systemctl status plexmediaserver
# Check installed package version
dpkg -l | grep plexmediaserver
Important Notes
  • This procedure will temporarily stop your Plex server
  • Consider backing up your Plex configuration before proceeding
  • Configuration location: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/
Step 1: Stop Plex Service
sudo systemctl stop plexmediaserver
Step 2: Download Target Version
Download the specific 1.41.6 release package:
wget https://artifacts.plex.tv/plex-media-server-stable/1.41.6.9685-d301f511a/debian/plexmediaserver_1.41.6.9685-d301f511a_amd64.deb
Note: This download link was sourced from the Plex community forums thread addressing core component errors.
Step 3: Install Downgraded Version
Use dpkg to install the older version:
sudo dpkg -i plexmediaserver_1.41.6.9685-d301f511a_amd64.deb
Expected output should show:
dpkg: warning: downgrading plexmediaserver from 1.42.1.10054-f333bdaa8 to 1.41.6.9685-d301f511a
PlexMediaServer install: PlexMediaServer-1.41.6.9685-d301f511a - Installation successful.
Step 4: Start Plex Service
Restart the Plex service with the downgraded version:
sudo systemctl start plexmediaserver
Verification
Check Service Status
Verify the service is running correctly:
Look for:
  • :white_check_mark: Active: active (running)
  • :white_check_mark: Version string showing 1.41.6.9685-d301f511a
  • :white_check_mark: Multiple plugin processes loaded successfully
Verify Version
Confirm the downgrade was successful:
# Check service output for version string
sudo systemctl status plexmediaserver | grep "server-version"
Should show: --server-version 1.41.6.9685-d301f511a
Test Web Interface
Access your Plex web interface to confirm functionality:
http://your-server-ip:32400/web
Prevention (Optional)
Hold Package Version**#**
To prevent automatic updates back to the problematic version:
sudo apt-mark hold plexmediaserver
Remove Hold (When Ready to Update)
When you want to allow updates again:
sudo apt-mark unhold plexmediaserver
Folks,
Having chatted with Engineering, here is the official workaround while they fix the problem.
Closing this thread in favor of the centralized thread.
