Server Version#: latest
Player Version#: latest
I had plex not opening and tried for 4 days with no success. I have 5 backups (over 10days) of the databases.
So i have done a fresh install which of course has the watched info missing. I have over 10,000 watched shows and movies info now missing . The database 5 backups I added to the correct folder
but none would open as per the original.
My question is there software that might check these DB and see if corrupt and fix .
I would really like my watched info back !!
dbirch
March 26, 2023, 4:38pm
2
If you restore the corrupt database ChuckPa as a nice tool for fixing that:
Thanks, I have gone over the readme several times.
I want to check plex DB on 2 Qnap NAS but can’t even get to the install part .
I do have the folder extracted
Your best bet is reading here, and asking questions.
Any chance you could make it support binhex-plexpass docker? My library db is 1.4gb and my blobs one is 4.09 gb. #_# I may need helps lol…
I asked cause I got this error below when attempting to execute it inside my docker container for binhex
Error: Unknown host. Currently supported hosts are: QNAP, Synology, Netgear, Mac, ASUSTOR, WD (OS5) and Linux Workstation/Server
dbirch
March 27, 2023, 11:10am
5
@ChuckPa Any chance you can provide some guidance?
thanks Dbirch
And thanks Chuckpa if u can give me “Fix Plex DB with PlexDBRepair for dummies”
The ‘Fix DB for dummies’ on QNAP
Get the file and put in /share/Public
SSH / Putty into the box
sudo bash to gain root privilege
cd /share/Public
tar xf PlexDBRepair*.tar.gz (if you got the tar.gz file
chmod +x DBRepair.sh
./DBRepair.sh stop auto start exit
PS: If you want to interact with the new UI,
./DBRepair.sh
then you can type the sequence of commands (one at a time)
stop
auto
start
— check PMS and confirm working
— If good – then type ‘exit’
— If not, ‘replace’ and let it find the most recent backup to use and install for you
Thanks Chuck
With lots of trial and error I managed to ‘repair’ my DB to the stage it works .
But some of my watched is missing !!
THe repair gives me this message when trying automatic
./DBRepair.sh: line 208: [: 74%: integer expression expected
Error: Unable to run automatic sequence. Insufficient free space available on /share/CACHEDEV4_DATA/.qpkg/PlexMediaServer/Library
Space needed = 8457 MB, Space available = MB
Enter command # -or- command name (4 char min) : 6
Error: Unable to perform processing. Insufficient free space available on /sh are/CACHEDEV4_DATA/.qpkg/PlexMediaServer/Library
The drive is 500gb and nothing on it except plex!!
Wow.
I will work on that. If you’re at that level, something is wrong because you should NEVER get a ‘%’ result from ‘stat’
190 FreeSpaceAvailable() {
191
192 Multiplier=3
193 [ "$1" != "" ] && Multiplier=$1
194
195 # Available space where DB resides
196 SpaceAvailable=$(df -m "$AppSuppDir" | tail -1 | awk '{print $4}')
197
198 # Get size of DB and blobs, Minimally needing sum of both
199 LibSize="$(stat $STATFMT $STATBYTES "$CPPL.db")"
200 BlobsSize="$(stat $STATFMT $STATBYTES "$CPPL.blobs.db")"
201 SpaceNeeded=$((LibSize + BlobsSize))
202
203 # Compute need (minimum $Multiplier existing; current, backup, temp and room to write new)
204 SpaceNeeded="$(expr $SpaceNeeded '*' $Multiplier)"
205 SpaceNeeded="$(expr $SpaceNeeded / 1000000)"
206
207 # If need < available, all good
208 [ $SpaceNeeded -lt $SpaceAvailable ] && return 0
209
210 # Too close to call, fail
211 return 1
212 }
it tells me your df -m /var/lib/plexmediaserver isn’t structured like everyone.
What do you get with that command ?
[chuck@lizum Downloads.2020]$ df -m /var/lib/plexmediaserver/
grep: invalid max count
[chuck@lizum Downloads.2021]$ /bin/df -m /var/lib/plexmediaserver/
Filesystem 1M-blocks Used Available Use% Mounted on
/dev/nvme0n1p2 124870 30689 94182 25% /
[chuck@lizum Downloads.2022]$ /bin/df -m /var/lib/plexmediaserver/ | tail -1 | awk '{print $4}'
94182
[chuck@lizum Downloads.2023]$
there’s no “%”
[~] # df -m /var/lib/plexmediaserver
df: /var/lib/plexmediaserver: can’t find mount point
Sorry…
On QNAP, it’s not safe to specify (my fault)
df -h
Retaining all temporary work files.
[/share/Public] # df -h
Filesystem Size Used Available Use% Mounted on
none 400.0M 316.1M 83.9M 79% /
devtmpfs 23.5G 4.0K 23.5G 0% /dev
tmpfs 64.0M 2.3M 61.8M 4% /tmp
tmpfs 23.5G 164.0K 23.5G 0% /dev/shm
tmpfs 16.0M 0 16.0M 0% /share
/dev/sdo5 7.7M 52.0K 7.3M 1% /mnt/boot_config
tmpfs 16.0M 0 16.0M 0% /mnt/snapshot/export
/dev/md9 499.5M 189.0M 310.6M 38% /mnt/HDA_ROOT
cgroup_root 23.5G 0 23.5G 0% /sys/fs/cgroup
/dev/mapper/vg1-lv1313
38.6M 40.0K 38.6M 0% /mnt/pool1
/dev/mapper/vg2-lv1312
6.4G 11.8M 6.4G 0% /mnt/pool2
/dev/mapper/cachedev1
379.0G 123.3G 255.1G 33% /share/CACHEDEV1_DATA
/dev/mapper/cachedev2
63.1T 48.0T 15.2T 76% /share/CACHEDEV2_DATA
/dev/mapper/cachedev3
403.2G 99.9G 302.7G 25% /share/CACHEDEV3_DATA
/dev/mapper/cachedev4
723.4G 535.3G 187.5G 74% /share/CACHEDEV4_DATA
/dev/md13 417.0M 384.3M 32.7M 92% /mnt/ext
tmpfs 32.0M 27.2M 4.8M 85% /samba_third_party
tmpfs 1.0M 0 1.0M 0% /share/external/.nd
tmpfs 1.0M 0 1.0M 0% /share/external/.cm
tmpfs 1.0M 0 1.0M 0% /mnt/hm/temp_mount
tmpfs 1.0M 0 1.0M 0% /share/.quftp_client
tmpfs 8.0M 0 8.0M 0% /var/syslog_maildir
tmpfs 16.0M 0 16.0M 0% /share/NFSv=4
379.0G 123.3G 255.1G 33% /share/NFSv=4/Public
/dev/mapper/vg1-snap10001
379.1G 175.0G 203.5G 46% /mnt/snapshot/1/10001
/dev/mapper/vg1-snap10002
379.1G 150.0G 228.6G 40% /mnt/snapshot/1/10002
/dev/mapper/vg1-snap10003
379.1G 158.8G 219.7G 42% /mnt/snapshot/1/10003
/dev/mapper/vg1-snap10004
379.1G 160.7G 217.9G 42% /mnt/snapshot/1/10004
/dev/mapper/vg1-snap10005
379.1G 161.9G 216.7G 43% /mnt/snapshot/1/10005
/dev/mapper/vg1-snap10006
379.1G 121.9G 256.7G 32% /mnt/snapshot/1/10006
/dev/mapper/vg1-snap10007
379.1G 122.5G 256.1G 32% /mnt/snapshot/1/10007
/dev/mapper/vg1-snap10008
379.1G 123.0G 255.6G 32% /mnt/snapshot/1/10008
/dev/mapper/vg1-snap10009
379.1G 123.3G 255.3G 33% /mnt/snapshot/1/10009
723.4G 535.3G 187.5G 74% /lib/modules/5.10.60-qnap/container-station
tmpfs 100.0K 0 100.0K 0% /share/CACHEDEV4_DATA/VMs/container-station-data/lib/lxd/shmounts
tmpfs 100.0K 0 100.0K 0% /share/CACHEDEV4_DATA/VMs/container-station-data/lib/lxd/devlxd
overlay 723.4G 535.3G 187.5G 74% /share/CACHEDEV4_DATA/VMs/container-station-data/lib/docker/overlay2/a9227a48297880850361362359b7591eeac2880241b6ea5451a0a770f3291c21/merged
overlay 723.4G 535.3G 187.5G 74% /share/CACHEDEV4_DATA/VMs/container-station-data/lib/docker/overlay2/6083c11ed7e53ae839434bb0d5ccf95cb7750c405961068e6dd6e5c8c830278a/merged
overlay 723.4G 535.3G 187.5G 74% /share/CACHEDEV4_DATA/VMs/container-station-data/lib/docker/overlay2/7a5abd2293d4d44801ee0c7cab2b0c5ccd144426b7bc23c4275f4386deb98537/merged
overlay 723.4G 535.3G 187.5G 74% /share/CACHEDEV4_DATA/VMs/container-station-data/lib/docker/overlay2/db23e8bb9e51bd697db0d4c40ed2d0d9039d432ebce361cf1f3cc9f214f2fddc/merged
overlay 723.4G 535.3G 187.5G 74% /share/CACHEDEV4_DATA/VMs/container-station-data/lib/docker/overlay2/d6bbf7354b76afd0d6bf04f43c8f834bb3e0af5efdf30c0edea294e2bcaaab24/merged
overlay 723.4G 535.3G 187.5G 74% /share/CACHEDEV4_DATA/VMs/container-station-data/lib/docker/overlay2/15eddc61457ac7841e9a0d50f515aa686d0ea5d940941041721759cc052bf740/merged
overlay 723.4G 535.3G 187.5G 74% /share/CACHEDEV4_DATA/VMs/container-station-data/lib/docker/overlay2/f9c632a56860e65b6b24295814058f2e7e41e427c81d74383026dcba8029f6b4/merged
overlay 723.4G 535.3G 187.5G 74% /share/CACHEDEV4_DATA/.qpkg/container-station/system-docker/overlay2/4c18f272ee563eb29ca12fda8622ab091f0230b0074470c8f5a825fcc21156fb/merged
/dev/mapper/vg1-snap10010
379.1G 122.8G 255.8G 32% /mnt/snapshot/1/10010
tmpfs 48.0M 52.0K 47.9M 0% /share/CACHEDEV1_DATA/.samba/lock/msg.lock
tmpfs 16.0M 0 16.0M 0% /mnt/ext/opt/samba/private/msg.sock
/dev/mapper/vg1-snap10011
379.1G 127.4G 251.2G 34% /mnt/snapshot/1/10011
//192.168.1.18/DATA 50.5T 39.8T 10.6T 79% /mnt/RTRR_CIFS/192.168.1.18/admin/DATA
overlay 723.4G 535.3G 187.5G 74% /share/CACHEDEV4_DATA/.qpkg/container-station/system-docker/overlay2/7fef80fb400488ed4fb78326402f343132e494367eb7fa8ffb295bed05e069a6/merged
ftp://192.168.1.18:21//
7.5T 0 7.5T 0% /share/.quftp_client/db336ccd1d924c2ba651fd6c35d81292
/dev/mapper/vg1-snap10012
379.1G 123.4G 255.2G 33% /mnt/snapshot/1/10012
//192.168.1.18/media 50.5T 39.8T 10.6T 79% /mnt/RTRR_CIFS/192.168.1.18/admin/media
[/share/Public] #
MODERATOR EDIT: Legibility
Chuck , What time are u at your “help” desk and where r you ?
I am GMT +8 .
I am EST/EDT (New York time zone)
I see, and have now fixed the problem.
Please download v1.0.3.
You’ll notice it speaks to QTS/QuTS (where this occurs)
Thanks Chuck ,
I really appreciate your help.
I think I am back into the Plex world !!
But get this on NAS #2
Enter command # -or- command name (4 char min) : 2
Unable to run automatic sequence. PMS is running. Please stop PlexMediaServer.
Cannot stop PlexMediaServer. Tried in script several times and from Qnap.
Nothing stops it !
