Could not tune channel. Please check your tuner or antenna
I am running plex in a docker container using the plexinc/pms-docker image and a HDHomeRun EXTEND.
It was working fine. Not sure when it stopped, but now I cannot see or record Live TV.plex.log (364.2 KB)
From Plex Server Log:
Aug 12, 2020 06:44:10.549 [0x7f921effd700] ERROR - Unable to find title for item of type 5
Aug 12, 2020 06:44:35.583 [0x7f921effd700] ERROR - Failed to start session.
Aug 12, 2020 06:44:35.583 [0x7f921effd700] ERROR - Recorder: Unable to create transcode session or session failed to start.
Aug 12, 2020 06:44:35.583 [0x7f921effd700] ERROR - Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Aug 12, 2020 06:44:35.584 [0x7f921effd700] ERROR - Grabber: Starting media grab failed.
Aug 12, 2020 06:44:35.584 [0x7f921effd700] ERROR - Unknown metadata type:
Aug 12, 2020 06:44:35.584 [0x7f91ec7f0700] ERROR - Subscription: Rolling media grab failed to start.
Didn’t figure out exactly why, but I discovered the cause. I have plex running in docker on vSphere. If I have it on a NSX backed network, it cannot stream from the hdhomerun. I moved it to a standard port group on a dvswitch and it works again.
