Could not tune channel. Please check your tuner or antenna
I receive the following error when trying to play/channel via Plex using in this case Threadfin. About a year ago I had it working but that was via a dvb-t dongle not using something such as Threadfin.
Server Version#: 1.42.1.10060
Tuner Make/Model: Using Threadfin 1.2 (35)
Guide/Lineup name:
Using XMLTV?: Yes
Channel number/Name: 15
Plex docker logs:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 40-plex-first-run: executing...
Plex Media Server first run setup complete
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing...
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing...
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
Critical: libusb_init failed
Connection to 172.104.62.188 closed by remote host.
Stopping Plex Media Server.
kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
Edit:
Here are the Plex server logs:
Plex Media Server Logs_2025-08-17_12-10-12.zip (584.8 KB)
Thanks,
Aaron
Tried going back to version 1.41.0.8994-f2c27da23 but still the original problem persists. Also, installed Plex player same message appears there too.
Plex is only using secure connections these days, so your docker should use host mode for networking. Get this working correctly and you might solve your other issue.
Threadfin support will have to happen elsewhere.
Yeah, I change the Plex container type“–net“ to “host“ but same problem but thanks for the input.
