Hi!
I’ve installed PMS on a Raspberry Pi 4 using docker and everything was working fine until yesterday. I’ve noticed that that right after i start the container that the CPU usage goes to 100% all the time. The server is so unresponsive that i can’t connect to the server using the android apps and I can’t get to the server settings and the only thing i can see it this message “Server settings are unavailable.” (I know this doesn’t help a lot xD)
I’m using the version from 23.11.20 from the container linuxserver/plex.
I can see these logs from portainer but I don’t know if it helps much.
[cont-init.d] 01-envfile: exited 0.,
[cont-init.d] 10-adduser: executing... ,
_ (),
| | ___ _ __,
| | / __| | | / \ ,
| | \__ \ | | | () |,
|_| |___/ |_| \__/,
Brought to you by linuxserver.io,
To support LSIO projects visit:,
https://www.linuxserver.io/donate/,
GID/UID,
User uid: 1000,
User gid: 1000,
[cont-init.d] 10-adduser: exited 0.,
[cont-init.d] 40-chown-files: executing... ,
[cont-init.d] 40-chown-files: exited 0.,
[cont-init.d] 45-plex-claim: executing... ,
[cont-init.d] 45-plex-claim: exited 0.,
[cont-init.d] 50-gid-video: executing... ,
[cont-init.d] 50-gid-video: exited 0.,
[cont-init.d] 60-plex-update: executing... ,
Docker is used for versioning skip update check,
[cont-init.d] 60-plex-update: exited 0.,
[cont-init.d] 99-custom-scripts: executing... ,
[custom-init] no custom files found exiting...,
[cont-init.d] 99-custom-scripts: exited 0.,
[cont-init.d] done.,
[services.d] starting services,
[services.d] done.,
Starting Plex Media Server.,
Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-d87012962/OpenSubtitles.bundle.,
Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-d87012962/LyricFind.bundle.,
Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-d87012962/LocalMedia.bundle.,
[cont-finish.d] executing container finish scripts...,
[cont-finish.d] done.,
[s6-finish] waiting for services.,
[s6-finish] sending all processes the TERM signal.,
[s6-finish] sending all processes the KILL signal and exiting.,
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.,
[s6-init] ensuring user provided files have correct perms...exited 0.,
[fix-attrs.d] applying ownership & permissions fixes...,
[fix-attrs.d] done.,
[cont-init.d] executing container initialization scripts...,
[cont-init.d] 01-envfile: executing... ,
usermod: no changes,
_ (),
| | ___ _ __,
| | / __| | | / \ ,
| | \__ \ | | | () |,
|_| |___/ |_| \__/,
GID/UID,
User uid: 1000,
User gid: 1000,
[services.d] done.,
Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-d87012962/MoviePosterDB.bundle.,
Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-d87012962/PlexMovieNew.bundle.,
Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-d87012962/LastFM.bundle.,
I’m very very noob to the docker and PMS stuff. Can anyone help me?
Server Version#: 1.20.5.3600-47c0d9038
