Host OS version: Raspbian GNU/Linux 10 (buster)
Hardware: Raspberry Pi 4, 4Gb RAM
Plex Media Server version: 1.27.1.1571-2fface66
Docker tag for the image: version-1.21.2.3943-a91458577
Brief description of the issue or bug: Whenever the server is running, the CPU is always loaded at 100% capacity, and whenever I try to play any media, I recieve the following error: An unknown error occurred (4294967283)
Steps to reproduce: Start docker container, then play any video
The last version that worked fine is PMS version 1.27.1.1571-2fface66 which corresponds to Docker image tag version-1.20.5.3600-47c0d9038, this particular image only loads the CPU to 30% when idle, and a maximum of 60% when playing something.
The same :
[After update 300% CPU is loaded - RP4 - docker]
Finally found the solution of this issue after literal weeks of searching:
https://docs.linuxserver.io/faq#my-host-is-incompatible-with-images-based-on-ubuntu-focal
In my case, I had to switch from “latest” to “bionic” image tags from dockerhub
