Server Version#: 1.19.3.2764
CPU won’t go below 30+%, even when nothing is being played.
I have 2 other servers and they don’t exhibit this behavior.
I have uploaded my logs from the troubled server and it shows the same message over and over.
I can’t see anything in that log to match the CPU usage. Have you checked the Window’s resource monitor to see what application is doing that. Could be a the scanner or a stray plugin.
You might have solved it for me with your comment about plugins. There were 2 plugins from a long time ago that I was playing with, but never really used them. I deleted them and rebooted and now my CPU is “flat-lining”, which in this case is a good thing.
I will monitor for a while and see if that was it.
Interesting. Plugins run through the python runner so it would show that. I wonder if it’s just PMS trying to load one of those plugins and getting stuck in a loop. Mind sharing what plugins they were?
One was Export Tools, and the other one was Web “something”
That might have been WebTools. If you keep both of them updated, they should still be able to work, without causing the unusual CPU load.
Thanks for the info.
Are you aware of any tool that can export the following:
It’s been too many years since I did any SQL work to figure out the correct query of the database to figure this out.
Thanks.
