While recently installing a new backup program, I ran into an error that I was told may have something to do with the PLEX plugin CRACKLE. Can someone tell me what this is for and what would be the result if I deleted it? I do no gaming…Win 10
C:\Users\weybr\Plex Media Server.09.20.20\Plug-ins\Services.bundle\Contents\Service Sets\com.plexapp.plugins.crackle
I’m having a problem with another program install and I have been told that the PMS plug-in CRACKLE is a potential problem. They suggest I delete it. Since your comment about “content plug-ins are dead anyway…” should I delete the entire CONTENTS > Service Sets folder?
That sounds unlikely… the plug-in is basically a bunch of scripts that are used by Plex. They don’t interfere with other programs/applications. Therefore that statement sounds suspicious/fishy (to me) – in particular if this is supposed to be a backup program
Generally I would keep the Services.bundle folder untouched. However from what I’ve been reading Plex will create whatever it requires for its inner workings on startup if it’s been deleted.
