Crash CE-34878-0
I’m getting the same error code CE-34878-0 after my Plex crashes. This is happening multiple times a day now.
I was having an issue to where it would crash whenever I tried to watch anything. I fixed it by restarting my PC which acts as my server. I hope this helps you all.
I have this same issue for a year now.
Please PLEX fix this
Still no fix!
I have a new PS4 and Plex is STILL crashing with CE-34878-0. It does the same thing with my PS3…
Fricking fix it!
It makes no difference what library I view, be it mine on my network or a friends elsewhere. it crashes…
It’s been a year and a half for you guys since these crashes!? This is unbelievable! I’ve just been experiencing this problem since past 8 months or so but I didn’t know it’s been there for years! Plex Management PLEASE DO SOMETHING ABOUT THIS! PLEASE! The app is absolutely unusable!
I’ve been having this issue the past couple of weeks. Never happens with movie always happens with shows. Almost every 45 minutes. Made the app completly unusable, any fix Come on boys?
When you see error code CE-34878-0, the first and easiest thing you should do is restart check to see if that is enough to make the problem fixed.
Following on this website also provide solution,
So here we are more than 2 years later and Plex staff has said NOTHING about this issue or even acknowledged the previous posts. Being a plex pass subscriber makes no difference in getting support. I have tried the various ideas posted here, but NONE are either consistent and provided NO solution. I recently wiped my plex server machine, did a full rebuild and the results are exactly the same and it makes no difference what show, file format, network configuration, the failure is consistent. PS4/PS3 fails with Plex ONLY. I get the same results connecting to my friend’s plex server as well, so the idea its a local network issue is not true. Its quite apparent to me the problem is the Plex app on any Sony Playstation. FIX IT!
I receive this error code, CE-34878-0, on PS4 daily and have for many months continuously.
Plex Support - what can I provide to help resolve this?
Why hasn’t then been addressed
Same error here brand new ps4 pro
can someone fix this finally ?
I am still having the problem can u fix it please this is unbelievable i am having the problem for a YEAR now and updates doesn’t fix it. it makes the app useless.
