Create unique library from two different servers
Server Version#: 1.22.3.4392
Hello
i have two different NAS (a QNAP and a SYNOLOGY) where film and specially tv series are located. Often happens that i have some episodes on a nas and others on another nas.
Actually i have setted two different library one for each nas, but i would like to know if it’s possible to create an unique library populated by two servers to have all series tv in one page.
Thank in advance
This might be an option. Both NAS must be on the same LAN. SMB & NFS generally do not play nice over WAN connections.
You should be able to mount directories from one NAS on the other using NFS or SMB. Then add the mounted directory to the desired library. All the media will appear in one library.
Example:
  • Running PMS on the Synology. You have an existing TV library, with files in /volume1/media/tv.
  • Share the desired directory on the QNAP via NFS & mount it on the Synology at /volume1/qnap/media/tv.
  • Edit the TV Show library on the Synology based PMS, adding the new library location.
  • PMS Synology scans the new location and adds the media to the library.
See thread below. It shows mounting a remote directory on a Synology. There should be a similar procedure for QNAP.
Simply…Thanks thanks thanks a lot.
I have follewd your suggest and now i have only one library.
GREAT!!!
Thanks again
