Credit Detection BufferingLineReader
Server Version#: v1.31.0.6654-02189b09f
Feb 17, 2023 11:04:47.729 [0x7ff002428b00] INFO - Plex Media Scanner v1.31.0.6654-02189b09f - Synology DS1517+ x86_64 - build: linux-x86_64 - GMT 11:00
Feb 17, 2023 11:04:47.729 [0x7ff002428b00] INFO - Linux version: DSM 6.2.4.25556-6, language: en-US
Feb 17, 2023 11:04:47.729 [0x7ff002428b00] INFO - Processor: 4-core         Intel(R) Atom(TM) CPU  C2538  @ 2.40GHz
Feb 17, 2023 11:04:47.729 [0x7ff002428b00] INFO - /volume1/@appstore/Plex Media Server/Plex Media Scanner -C -f /volume1/tvshows/######.mp4 --log-file-suffix  Credits
Feb 17, 2023 11:05:01.344 [0x7ff0024c8b40] ERROR - BufferingLineReader: failed to read line (error: -1)
Seems to be getting some credits, but I’m not sure if it’s pulling them from the web.
You will need to turn DEBUG logging back on so the devs can see what’s happening.
The error you report has been reported elsewhere
Feb 20, 2023 10:04:16.078 [0x7f77a0e51b00] INFO - Plex Media Scanner v1.31.0.6654-02189b09f - Synology DS1517+ x86_64 - build: linux-x86_64 - GMT 11:00
Feb 20, 2023 10:04:16.079 [0x7f77a0e51b00] INFO - Linux version: DSM 6.2.4.25556-6, language: en-US
Feb 20, 2023 10:04:16.079 [0x7f77a0e51b00] INFO - Processor: 4-core         Intel(R) Atom(TM) CPU  C2538  @ 2.40GHz
Feb 20, 2023 10:04:16.079 [0x7f77a0e51b00] INFO - /volume1/@appstore/Plex Media Server/Plex Media Scanner -C -f /volume1/tvshows/###.mp4 --log-file-suffix  Credits
Feb 20, 2023 10:04:16.070 [0x7f77a0ef1b40] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Feb 20, 2023 10:04:16.479 [0x7f77a0ef1b40] DEBUG - [ID -1] Media part analysis: /volume1/tvshows/###.mp4
Feb 20, 2023 10:04:16.479 [0x7f77a0ef1b40] DEBUG - [MI] Opening input file: "/volume1/tvshows/###.mp4"
Feb 20, 2023 10:04:16.479 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - Opening '/volume1/tvshows/###.mp4' for reading
Feb 20, 2023 10:04:16.479 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto,data'
Feb 20, 2023 10:04:16.480 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - Format mov,mp4,m4a,3gp,3g2,mj2 probed with size=2048 and score=100
Feb 20, 2023 10:04:16.480 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - ISO: File Type Major Brand: isom
Feb 20, 2023 10:04:16.480 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Feb 20, 2023 10:04:16.501 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - Processing st: 0, edit list 0 - media time: 1280, duration: 52804480
Feb 20, 2023 10:04:16.511 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - Offset DTS by 1280 to make first pts zero.
Feb 20, 2023 10:04:16.514 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - Setting codecpar->delay to 2 for stream st: 0
Feb 20, 2023 10:04:16.514 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - Unknown dref type 0x206c7275 size 12
Feb 20, 2023 10:04:16.533 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - Processing st: 1, edit list 0 - media time: 1024, duration: 158412288
Feb 20, 2023 10:04:16.533 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - drop a frame at curr_cts: 0 @ 0
Feb 20, 2023 10:04:16.544 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 180454231 bytes read:2537194 seeks:1 nb_streams:2
Feb 20, 2023 10:04:16.545 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Feb 20, 2023 10:04:16.546 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Feb 20, 2023 10:04:16.550 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Feb 20, 2023 10:04:16.550 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Feb 20, 2023 10:04:16.551 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Feb 20, 2023 10:04:16.551 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - nal_unit_type: 5(IDR), nal_ref_idc: 3
Feb 20, 2023 10:04:16.551 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - Format yuv420p chosen by get_format().
Feb 20, 2023 10:04:16.552 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - no picture
Feb 20, 2023 10:04:16.556 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Feb 20, 2023 10:04:16.557 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - no picture
Feb 20, 2023 10:04:16.561 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - demuxer injecting skip 1024 / discard 0
Feb 20, 2023 10:04:16.561 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - skip 1024 / discard 0 samples due to side data
Feb 20, 2023 10:04:16.561 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - All info found
Feb 20, 2023 10:04:16.563 [0x7f77a0ef1b40] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 14704 bytes read:2569962 seeks:2 frames:3
Feb 20, 2023 10:04:16.563 [0x7f77a0ef1b40] DEBUG - [MI] Opening "/volume1/tvshows/###.mp4" for MP4 atom parsing
Feb 20, 2023 10:04:16.563 [0x7f77a0ef1b40] DEBUG - Mp4AtomParser: Skipping ftyp atom of size 32 at offset 0
Feb 20, 2023 10:04:16.563 [0x7f77a0ef1b40] DEBUG - Mp4AtomParser: Skipping free atom of size 8 at offset 32
Feb 20, 2023 10:04:16.563 [0x7f77a0ef1b40] DEBUG - Mp4AtomParser: Skipping mdat atom of size 177949765 at offset 40
Feb 20, 2023 10:04:16.563 [0x7f77a0ef1b40] DEBUG - Mp4AtomParser: Found moov atom of size 2504426 at offset 177949805
Feb 20, 2023 10:04:16.565 [0x7f77a0ef1b40] DEBUG - Mp4AtomParser: Found trak atom of size 1307295 at offset 177949921
Feb 20, 2023 10:04:16.565 [0x7f77a0ef1b40] DEBUG - Mp4AtomParser: Found trak atom of size 1196917 at offset 179257216
Feb 20, 2023 10:04:16.565 [0x7f77a0ef1b40] DEBUG - Mp4AtomParser: Found mdia atom of size 1307159 at offset 177950057
Feb 20, 2023 10:04:16.565 [0x7f77a0ef1b40] DEBUG - Mp4AtomParser: Found minf atom of size 1307074 at offset 177950142
Feb 20, 2023 10:04:16.565 [0x7f77a0ef1b40] DEBUG - Mp4AtomParser: Found stbl atom of size 1307010 at offset 177950206
Feb 20, 2023 10:04:16.566 [0x7f77a0ef1b40] DEBUG - Mp4AtomParser: Found mdia atom of size 1196781 at offset 179257352
Feb 20, 2023 10:04:16.566 [0x7f77a0ef1b40] DEBUG - Mp4AtomParser: Found minf atom of size 1196696 at offset 179257437
Feb 20, 2023 10:04:16.566 [0x7f77a0ef1b40] DEBUG - Mp4AtomParser: Found stbl atom of size 1196636 at offset 179257497
Feb 20, 2023 10:04:16.581 [0x7f77a0ef1b40] DEBUG - [MI]  *  [mp4 h264/aac] Duration: 3300280ms, 640x480 (2.000000) 25.000fps, bitrate=437kbps, audio channels=2, optimizedForStreaming=0 ("/volume1/tvshows/###.mp4")
Feb 20, 2023 10:04:16.581 [0x7f77a0ef1b40] DEBUG - [MI] Chapters had generic titles, clearing.
Feb 20, 2023 10:04:16.581 [0x7f77a0ef1b40] DEBUG - [MI] Closing input file: "/volume1/tvshows/###.mp4"
Feb 20, 2023 10:04:16.592 [0x7f77a0ef1b40] DEBUG - [JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/7e8dc7a-4467-linux-x86_64/' "/volume1/@appstore/Plex Media Server/Plex Transcoder" -y -threads 0 -skip_frame noref -ss 2970 -i "/volume1/tvshows/###.mp4" -vf "[in]fps=0.5,scale=w=320:h=320:force_original_aspect_ratio=increase,showinfo[out]" -vsync 0 -f image2 "thumb-%05d.jpeg"
Feb 20, 2023 10:04:16.592 [0x7f77a0ef1b40] DEBUG - [JobRunner] In directory: "/volume1/Plex/tmp_transcoding/f805a906-20a6-4942-879e-d055fe72c545"
Feb 20, 2023 10:04:16.601 [0x7f77a0ef1b40] DEBUG - [JobRunner] Jobs: Starting child process with pid 1519
Feb 20, 2023 10:04:42.220 [0x7f77a0e9ab00] DEBUG - Jobs: '/volume1/@appstore/Plex Media Server/Plex Transcoder' exit code for process 1519 is 0 (success)
Feb 20, 2023 10:04:42.220 [0x7f77a0ef1b40] ERROR - BufferingLineReader: failed to read line (error: -1)
@elit3ge
They (Engineering) are aware of that error. Pretty sure they’ve got it resolved / nearly resolved and will be updating for the next PMS release.
