Cross-Server Playlist Issue After Recent Update
Hello Plex Team,
I’ve run into a puzzling issue since the last two updates, and it’s disrupting my cross-server playlist organization (a major point of my Plex OCD!). Here’s what’s happening:
Previously, I could seamlessly add movies to cross-server playlists directly from the “…/Add to” menu across all servers. However, now, whenever I try to add a movie to a cross-server playlist through this method, it doesn’t work.
Oddly enough, I’ve discovered a workaround: If I first create a playlist on one server, I can then navigate to that playlist, click the “…” menu within the playlist, and select “Add to Playlist.” From there, I’m able to add movies from any of my servers into the appropriate playlist.
Does this make sense? This roundabout process works, but it’s much more cumbersome than before, and I’d love to know if there’s a solution or if this is a known bug.
Thank you for any insights or guidance you can provide!
Normal Method: Add to Menu
Playlist Workaround Method:
