Server Version#: Version 4.108.0
Player Version#: Web
When I access Plex webGUI through Safari (it doesn’t seem to happen on Chrome or Firefox), I get a blank white page. If I use web inspect, I see the attached.
If I then refresh, it loads on the second attempt. It happens each time I try to connect for the first time in a while.
Anybody know what causes this?
What version of Safari are you using? What macOS version? And do you see the same behavior if you access the current, hosted version of the web client via https://app.plex.tv?
I’m using Safari Version 17.0 (18616.1.27.111.22, 18616) and the client (my laptop) is running Ventura 13.6 (22G120).
Those errors don’t happen with https://app.plex.tv. Through more testing I’ve found the issue goes away when I bypass the Authelia authentication app I run alongside NGINX. The Authelia app configuration must be interfering with something… I will investigate that more.
Thank you for the helpful response!
I sorted it out.
The issue was using https://plex.mydomain.com instead of https://plex.mydomain.com**/web**. I don’t understand exactly why that became an issue, but I added a line into my NGINX configuration so that, whenever the requested url is https://plex.mydomain.com, it re-directs to https://plex.mydomain.com/web, and now the issue is gone.
Example:
server {
listen 443 ssl;
listen [::]:443 ssl;
http2 on;
server_name plex.mydomain.com;
include /etc/nginx/conf.d/authelia_protectedapp_connection; # This forces user authentication through a separate app called Authelia... not needed for most folk
location / {
location = / {
return 301 /web;
proxy_pass https://192.168.32.106:32400;
include /etc/nginx/conf.d/authelia_protectedapp_config; # This forces user authentication through a separate app called Authelia... not needed for most folk
