I have the latest updates to the plex server running on my windows 10 home media server. I browsed to Settings>Live TV> clicked on the Channels link under my HomerunHD Prime area then changed the Guide Channels for the first 7 channels to map to the HD versions. Hit save and waited for guide to update, but they are not showing as available in main Guide. See screen shots attached. Is this a bug or am I missing a setting?
You have it backwards. We show you the data from the Guide and that maps back to the channel within the device. So to find ABC, you need to go to channel 104. It will then tune to the internal channel 4.
Ah got it. So if I want to have the guide show HD channel 104 in the channel 3 slot, then I need to declare channel 3 down where 104 is slotted, right?
Also, is there a way in the Roku TV channel guide menu for Plex to filter ONLY HD channels like the “HD Channels Only” dropdown in the browser UI?
Correct. The Roku does not yet have the ability to filter by HD only. This should come when the Grid View is added down the line.
