Has anyone else setup a custom comskip.ini file on the DVR folder created in the application folder? I followed this article https://support.plex.tv/articles/202915258-where-is-the-plex-media-server-data-directory-located/?_ga=2.161771836.105649107.1576685964-1858752458.1576519907 and setup a copy of the comskip.ini with one change. However now none of my commercials are being cut. Is there a way to grab the logs from the post process to remove commercials to see if there is an issue? I’m in NA and tried enabling the intelligent brightness in the file hoping it would help a bit but now it just doesn’t remove any commercials.
