Server Version#: PlexMediaServer-1.40.1.8227-c0dd5a73e-x86_64
I have setup port forwarding and a custom domain name but despite my best efforts to troubleshoot I cannot connect (refused) via http://plex.mydomain.com:0000/web it works fine via my android phone on data which leads me to believe that it’s something to do with my router & network settings, what’s really strange is it HAS worked and it seems to be a bit of an ongoing intermittent issue.
I can post logs if required but I would like to try and figure it out?
- Enable IPv6: Disabled
- Secure Connections: Preferred
- Custom certificate location:
- Custom cert encryption key:
- Custom Cert Domain:
- Network Interface: All Ethernet 192.168.1.xxx
- GSM Discovery: Enabled
- Remote Streams allowed: Unlimited
- LAN Networks: 192.168.0.0/24
- Treat WAN IP as LAN Bandwidth: Enabled
- Custom server access URLS: http://plex.mydomain.com
- List of IPs & networks allowed without auth:
- Webhooks: Enabled
