Custom Master TV Guide
Id like to suggest to have a feature where you can combine the tv guide from Plex live tv and all the live tv sources you might have from multiple servers. I have two plex servers setup with live tv. One using local channels with hdhomerun and the other using XTEVE to get international channels into plex. I cannot use both on the same box because of the limit on the guide source. Would be nice if you could just throw everything into one guide from multiple servers since we cannot do more than one guide sources on a single server.
Have a quick read of this - does it solve your issue (extract in bold below)?
Missing/Distant Channels
One of the issues we spent an entire year attempting to address with our first EPG change was was the omission of what might be considered distant OTA channels not appearing in a users local lineup. Hundreds of tickets were submitted with some variation of, “hey, this user in Batavia can in fact receive this channel from Buffalo”. It was a long arduous process but at some point, in some cases, the TiVo lineups became more accurate than the Gracenote lineups for the same postal code. Instead of going through this process all over again we’re inching closing to being able to ingest multiple lineups in a single DVR so users can correct any lineup omissions by simply adding a second lineup from another market to match against. This will have additional benefits as well. Do you have one CableCARD tuner configured for Spectrum Buffalo, but also point an antenna at Toronto for additional OTA channels? You’ll be able to do that.
