Custom section backgrounds
Back in the old versions of Plex Media Server with the old Media Manager, you had the option to set a custom background, that was shown in your Plex Clients in the main menu. In all recent clients you'll get a randomized slideshow instead.
I think this is pretty annoying and I like to have static images in the home/main menu.
![post-95727-0-28462000-1385302644.png|621x500](upload://qYt7NvSL9hQHR2LKjmT92Qnm2zg.png)
![post-95727-0-33278200-1385302646.png|212x92](upload://dy3xK61wVFaWtJZj7AVngx3BuTv.png)
![post-95727-0-72066600-1385302648.png|690x203](upload://sTXIsKif9EZIdK548rwZKa8n4eJ.png)
There is a little workaround/hack to get this old feature back, but it isn't supported by every skin, though. When take a look into the database of Plex, you'll notice that the column to set this custom background is still there:
![post-95727-0-69981400-1385302651.png|690x438](upload://5wzAZdiiW70REetuuuuehDxGWRY.png)
When you put the path to an image there, it will appear in the section properties on http://localhost:32400/library/sections
<Directory art="/library/sections/5/art/1385259546" filters="1" refreshing="0" ...
The Plex Aeon Skin was still supporting this old feature, but with the new "Plex Home Theatre" this stopped working and my home screen looks like that now:
![post-95727-0-75019500-1385303595.png|690x431](upload://g3Xb1c6Q7TtFzXLaJrREqrbeZlV.png)
For older versions of the Plex Client (with Aeon Skin), you can get the custom backgrounds by setting:
- Settings > Appearance > Skin > Enable Global Slideshow -> off
- Settings > Customize > Advanced > Home > Use Fanart Slideshow -> off
![post-95727-0-22980300-1385302662.png|690x431](upload://qfFgz5E2JSSF2Gz0IXVrUsaEFP8.png)
duplicate - please search -> https://forums.plexapp.com/index.php/topic/58024-custom-background-folder-slideshow/?hl=%2Bcustom+%2Bbackground
