Daily Plexamp Quirks (Visual Studio / Monitor Change)
Hi Guys
Loving Plexamp so far and now using it 100% while working. However I have two quirks which both are forcing me to restart the app daily.
  1. It appears you have globally assigned the CTRL+ALT+SPACE key binding, this overrides the same key binding in Microsoft Visual Studio for the “Show parameter info” shortcut which I (and others) use all the time. If this could be changed to another combination or not made global that would really really help.
  2. Every time i dock my surface pro and the monitors resize (some from high to low DPI) the Plexamp UI kind of screws up, only way to correct is to restart.
Take a look at the release notes (v1.01) for how to change the keybindings:
http://forums.plex.tv/discussion/303432/plexamp-release-notes
