Dash app not showing server
IPadOS now working fine. Good job crew!
Samsung Z fold 3 Working :+1:
Can I just check does the new app[ crash for anyone else on iPhone when they select the “Server Graphs” tab - or is it just me?
As an FYI… Its not crashing for me on android and is working well. Have you attempted uninstalling and installing again?
Not crashing here for server graphs on an iPhone with iOS 15.1
Thanks for that - I too am on 15.1 and no matter what I try it crashes when I select the tab. It pauses for a while then shows the first graph briefly, none of the others appear and then crash! Im on a iPhone 12 pro, with os 15.1.
Thanks for that - that is the only thing that I haven’t tried - I’ll give it a go…
Made no difference sadly…
Finally solved it - in case anyone else has a similar problem. I logged out of my account on the server and restarted the server and re-logged in - cleared the app crashing…
Same issue on my iPhone 12 Pro, iOS 15.1 (mentioned here). Tried with the following tips and the problem solved:
  1. Turn on AirPlane mode and turn off. Not Working
  2. Restart your iPhone. Not working
  3. Delete Dash app and redownload to App Store. Works!
Android 12 on a Pixel 4a here.
Plex Dash hasn’t worked for over a month.
After coming back here to see if a solution is available yet, I see the comment right above mine.
So I deleted the app from my phone, redownloaded, signed back in and now it works again.
