Plex Dash doesn't work after update v1. 1.0
The application doesn’t launch after the update. Even after a fresh reinstall it’s still crashing…
How could I report it to help solving this bug ? (previous version was working great)
Android Lineage OS 17.1
Xiaomi Note 8
Just FYI for troubleshooting
Working without issue on iOS 15.1 on iPhone 7, iPhone 11 and iPad 6th Gen
Thank you. I think it should run great on most of the device, but as it doesn’t on mine i would like to help fixing the problem :slight_smile:
what version of android is that?
If it’s crashing on launch, we might need to get a logcat from you.
The new app crashes for me also on iPhone 12 pro with OS 15.1. The app runs until I select th e"server graphs" tab, where it crashes after displaying the server graph (none of the others appear).
I just tried that on my iPhone 7 and 11
Didn’t crash.
I even tried deleting the app and reinstalling - still crashes when I select server graphs…
working fine for me on iPhone 12 Pro running iOS 15.1
Thank you for your reply.
It’s Android 10.
Well, how can I get those logs ?
Finally solved it my app crashing - in case anyone else has a similar problem. I logged out of my account on the server and restarted the server and then re-logged into my Plex account - it cleared the app crashing…
Here it is : logs-2021-11-03-13-58-00.zip (1.3 KB)
Unfortunately those logs are pretty much empty and don’t have any usable information.
Ok, i know why. I’ll come back later with usuable ones.
After adding the “micro G” to the Lineage os rom it work again.
So, problem solved :slight_smile:
