Dashboard Graphs Scale
Hi!
I love the graphs and info on the dashboard, however the graphs can be somewhat hard to read due to the vertical scale. The horizontal lines for the scale are not placed logically. It is always scaled according to the highest bar. If the bar is 11.1, the rest of the lines will be at 2.2, 4.4, 6.7 and so on.
It would be easier to read the graph if the lines had standardized intervals. The graph mentioned would be easier to read if it had interval at 2, 4, 6, 8, 10, 12.
Depending to the scale needed you can have lines at every 1, 2, 5 or 10… according to what is needed. Then comparing different bars on the graph would be much easier. Especially bars that are between two lines as you can easily think your way to the value between those lines.
Regards,
BroderLund
Using the cursor the dashboard graphs give data points with required data. I see no need for your request.
