Recently I’m seeing this issue. There are two streams that are NOT paused and working just fine but the graph is not showing the activity for the first 30seconds:
Does this happen across all devices? This is usually caused by your server’s clock being out of sync with the client.
Ah, that would make sense. I was using a client that had been offline for quite some time.
And, it does appear other devices are not having the same issue.
Thank you!
