database location as variable
is there a way to specify the database location for Plex? if not can I ask for a feature request?
currently my Plex is on linux and the OS is running on SSD however my /var/lib/plexmediaserver is mounted from normal drives and I am getting a few slow query in the logs
Jun 05, 2018 19:16:44.779 [0x7f41953fc700] WARN - SLOW QUERY: It took 270.000000 ms to retrieve 50 items.
Jun 05, 2018 19:17:09.799 [0x7f418c7fc700] WARN - SLOW QUERY: It took 300.000000 ms to retrieve 50 items.
(yes my database is optimized and not corrupt - already performed it earlier today)
if its possible to specify the database location i would much prefer to put the database on the ssd drive instead of having it on the data drive.
I know that we can nest mount the database directory or create symlinks but i think having the database location as variable that we can adjust would be much cleaner.
Early 2021 clean-up: implemented/possible
