Date format wrong for Web Shows
I am not a US citizen and use the date format DD/MM/YY
As Web Shows are a new thing, can you please use regional date formats
MM/DD/YY looks confusing for other countries
Could you tell me where you are seeing that. I am seeing dates in format ‘dd mmm yyyy’
Screenshot ?
Here you go
First page when i go into WebShows
Then just pick any show and go to details
Exactly the same if i go to Podcasts, News or the DVR
I am in the UK and my PC is correctly set to UK
For info, these are my Windows settings
Thank you for the screenshots. So it is Plex Web. What I checked was Plex for iOS and that was ok.
I will refer this to the web team
FYI This also occurs on Podcasts - appears to have hard-coded MM/DD/YY styling.
Webshows / Podcasts / EPG
bump,
any update on this?
now i have noticed I can’t help but stare.
I do not have any update. The issue has been registered with the Plex Web team
I expect a very long wait for this
Been mentioned in the past about this (DVR has this issue also) and its not been fixed
It’s a bit pathetic really, that companies hard code to just use US date formats, instead of using the regional date format set on the PC/Server
This should be resolved now - please try https://app.plex.tv/desktop and let me know
That is fantastic, Thanks :slight_smile:
Just checked some DVR recordings, News, Podcasts & Web Shows and all have the correct format now
Cheers
Thanks for the confirmation, I am going to close this topic now - if you spot any other areas please raise a new topic
Thank you
